Just installed the packages from PCLoadLetter.co.uk on my brand new syno. (thanks to him)
Trying to sync the designer with the controller I obtain the following error message:
Downloading account configuration failed : Unsupported curve: 1.2.840.10045.3.1.7
Any idea to solve the issue?
Thanks in advance.
Just for your information, the issue has been solved by switching from de Synology Java 8 to the Java 7 package.
Regards,
Nicolas
Hi.
Today I also tried to install a package Java8 from synocommunity instead psloadletter Java8 package (which I can not sync online with designers because crypto error).
And I was even able to sync online with the designer!!! But then I got the same error when sync with designers like you. I wonder why this is happening? Several times online sync normally, then an error (with Java8 from synocommunity).
I reinstalled, and install Java7, and only now everything works fine, including the rules sending mail (javaxmail).
I really wonder why 2 months ago everything worked fine with package Java8 (from psloadletter), and now only from Java7 synocommunity?
Thankyou.
