I added a when-then rule for sending emails to admin but in the logs i got this:
is there some configuration to do before adding when-then rules
Could you check if there is an email address in the field of the user page?
Yes There is an address in the field. Even if I choose a custom attribute and add my address I got the same error
then check your email credentials in the docker-compose.yml
there must be an issue with it, cause there is no known issues with the email notifier.
hi Denis ,
can u share the yml congig file for gmail
Email related environment variables are described in deploy.yml to use gmail SMTP you need to generate an app password:
