So this is my directory structure:
C:.
│ docker-compose.yml
└───deployment
│ openremote.log.0
├───manager
│ │ keycloak.json
│ └───app
│ │ manager_config.json
│ └───images
└───map
mapdata.mbtiles
mapsettings.json
This is my docker-compose.yml:
# OpenRemote v3
version: '2.4'
proxy-data:
temp-data:
postgresql-data:
# btmesh-data:
services:
proxy:
restart: always
depends_on:
manager:
condition: service_healthy
ports:
- "80:80"
- "${OR_SSL_PORT:-443}:443"
- "8883:8883"
- proxy-data:/deployment
LE_EMAIL: ${OR_EMAIL_ADMIN:-}
postgresql:
restart: always
- temp-data:/tmp
keycloak:
restart: always
depends_on:
postgresql:
- ./deployment:/deployment
manager:
# privileged: true
restart: always
depends_on:
keycloak:
OR_SETUP_TYPE:
OR_ADMIN_PASSWORD:
OR_SETUP_RUN_ON_RESTART:
OR_EMAIL_HOST:
OR_EMAIL_USER:
OR_EMAIL_PASSWORD:
OR_EMAIL_X_HEADERS:
OR_EMAIL_FROM:
OR_EMAIL_ADMIN:
OR_FORECAST_SOLAR_API_KEY:
OR_OPEN_WEATHER_API_APP_ID:
- temp-data:/tmp
# - /var/run/dbus:/var/run/dbus
# # Bluetooth mesh volume
# - btmesh-data:/btmesh
# devices:
# - /dev/ttyACM0:/dev/ttyS0
And my mapsettings.json:
(the coordinates are of the city of Karlsruhe, i downloaded the map from Planet OpenStreetMap Tiles, GeoData and OpenData Maps | MapTiler Data)
"options": {
"default": {
"center": [ 8.4, 49.0 ],
"bounds": [ 8.27, 48.94, 8.55, 49.1 ],
"zoom": 14,
"maxZoom": 19,
"boxZoom": false,
"geocodeUrl": "https://nominatim.openstreetmap.org"
"version": 8,
"sources": {
"vector_tiles": {
"type": "vector",
"url": "mbtiles://mapdata.mbtiles"
"sprite": "map/sprites/bright-v9",
"glyphs": "{fontstack}/{range}.pbf",
"layers": [
"id": "background",
"type": "background",
"paint": {
"background-color": "#ecf2ea"
"id": "landcover-glacier",
"type": "fill",
"metadata": {
"mapbox:group": "1444849388993.3071"
"source": "vector_tiles",
"source-layer": "landcover",
"filter": [
"subclass",
"glacier"
"layout": {
"visibility": "visible"
"paint": {
"fill-color": "#fff",
"fill-opacity": {
"base": 1,
"stops": [
[ 0, 0.9 ],
[ 10, 0.3 ]
