Is there a way to integrate the EMQX MQTT broker ? on Openremote 3.0 .
Which MQTT engine it is use by default ?
@Michael is the most competent to answer this question.
I would also like to be able to integrate into EMQX
Our manager has an MQTT broker based on moquette, I assume you want to connect EMQX broker to OpenRemote which would mean using OpenRemote as an MQTT client…we currently don’t have an MQTT agent but one will be added soon.
If you want to connect to the OpenRemote MQTT broker from an MQTT client then see:
