Hi there,
I have OpenRemote up and running at https://openremote.dynamicdevices.co.uk
When I try to connect the mobile app (iOS) I get the following error. I think I have this right from the documentation. Can anybody advise please?
Thanks,
Alex
Hi there,
Thanks,
Alex
First of all, welcome to the forum! ![]()
The URL in the consoles should be prefixed with https:// on this page. ![]()
After that, it will try requesting several configuration files from the server.
However, I tried it out for myself using your URL here, but I got this error;
ERROR 500: "/deployment/manager/app is not a directory"
Can you double check if you’ve correctly set up the volumes / environment variables?
Because, what does your deployment look like? Are you building from the custom project template?
Hi there!
Thanks Martin!
I just followed these instructions - Quick Start | OpenRemote Documentation
Cheers,
Alex
I’ve been through the custom-template documentation but am having a lot ot trouble.
I just want to try the quickstart and connect up the mobile application at the moment. Any thoughts on what’s going wrong here?
Thanks!
