Hello all, I have a problem, when iam connecting Read attributes to the write attributes Error coming “No attributes with ‘rule state’ or ‘agent link’ configuration item found”. Please tell a solution.
Hi @aishwaryam
If you want to use an attribute in rules you need to add “rule state” as configuration item of the attribute.
Go to the asset->edit->find the attribute you want to work with->add “rule state” to that attribute
