Hi.
I`am new to OpenRemote, Docker and Ubuntu ![]()
I have set up a Ubuntu 20.04 machine with Docker 20.10.18 installed.
When i follow the installation procedure from: [openremote/README.md at master · openremote/openremote · GitHub] I get ann error when running the KeyCloak container. Please see attached log.
2022-10-05 08:53:44,105 INFO [org.jgroups.protocols.pbcast.GMS] (keycloak-cache-init) 77b1ed293708-27672: no members discovered after 2002 ms: creating cluster as coordinator
2022-10-05 08:53:44,111 INFO [org.infinispan.CLUSTER] (keycloak-cache-init) ISPN000094: Received new cluster view for channel ISPN: [77b1ed293708-27672|0] (1) [77b1ed293708-27672]
2022-10-05 08:53:44,114 INFO [org.infinispan.CLUSTER] (keycloak-cache-init) ISPN000079: Channel ISPN local address is 77b1ed293708-27672, physical addresses are [172.19.0.3:49287]
2022-10-05 08:53:51,254 WARN [io.agroal.pool] (agroal-11) Datasource ‘’: The connection attempt failed.
2022-10-05 08:53:51,257 WARN [org.hibernate.engine.jdbc.env.internal.JdbcEnvironmentInitiator] (JPA Startup Thread: keycloak-default) HHH000342: Could not obtain connection to query metadata: org.postgresql.util.PSQLException: The connection attempt failed.
- at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:331)*
- at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:49)*
- at org.postgresql.jdbc.PgConnection.(PgConnection.java:223)*
- at org.postgresql.Driver.makeConnection(Driver.java:400)*
- at org.postgresql.Driver.connect(Driver.java:259)*
- at java.sql/java.sql.DriverManager.getConnection(DriverManager.java:677)*
- at java.sql/java.sql.DriverManager.getConnection(DriverManager.java:228)*
- at org.postgresql.ds.common.BaseDataSource.getConnection(BaseDataSource.java:103)*
- at org.postgresql.xa.PGXADataSource.getXAConnection(PGXADataSource.java:49)*
- at org.postgresql.xa.PGXADataSource.getXAConnection(PGXADataSource.java:35)*
- at io.agroal.pool.ConnectionFactory.createConnection(ConnectionFactory.java:216)*
- at io.agroal.pool.ConnectionPool$CreateConnectionTask.call(ConnectionPool.java:513)*
- at io.agroal.pool.ConnectionPool$CreateConnectionTask.call(ConnectionPool.java:494)*
- at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)*
- at io.agroal.pool.util.PriorityScheduledExecutor.beforeExecute(PriorityScheduledExecutor.java:75)*
- at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1126)*
- at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)*
- at java.base/java.lang.Thread.run(Thread.java:829)*
Caused by: java.net.SocketTimeoutException: connect timed out - at java.base/java.net.PlainSocketImpl.socketConnect(Native Method)*
- at java.base/java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:412)*
- at java.base/java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:255)*
- at java.base/java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:237)*
- at java.base/java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)*
- at java.base/java.net.Socket.connect(Socket.java:609)*
- at org.postgresql.core.PGStream.createSocket(PGStream.java:241)*
- at org.postgresql.core.PGStream.(PGStream.java:98)*
- at org.postgresql.core.v3.ConnectionFactoryImpl.tryConnect(ConnectionFactoryImpl.java:109)*
- at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:235)*
So I`m not able to run the OpenRemote.
Does anyone have a tip how to fix this error.
Thanks in advanced
