Hi everyone,
I’m trying to test the email functionality in my OpenRemote deployment using Docker Compose, but I’m running into some issues. I followed the documentation and set up my docker-compose.yml file with the email settings as below:
# OpenRemote v3
# Profile for deploying the custom stack; uses deployment-data named volume
# to expose customisations to the manager and keycloak images. To run this profile you need to specify the following
# environment variables:
# OR_ADMIN_PASSWORD - Initial admin user password
# OR_HOSTNAME - FQDN hostname of where this instance will be exposed (localhost, IP address or public domain)
# DEPLOYMENT_VERSION - Tag to use for deployment image (must match the tag used when building the deployment image)
# Please see openremote/profile/deploy.yml for configuration details for each service.
# To perform updates, build code and prepare Docker images:
# ./gradlew clean installDist
# Then recreate deployment image:
# DEPLOYMENT_VERSION=$(git rev-parse --short HEAD)
# MANAGER_VERSION=$(cd openremote; git rev-parse --short HEAD; cd ..)
# docker build -t openremote/manager:$MANAGER_VERSION ./openremote/manager/build/install/manager/
# docker build -t openremote/custom-deployment:$DEPLOYMENT_VERSION ./deployment/build/
# docker-compose -p custom down
# docker volume rm custom_deployment-data
# Do the following volume rm command if you want a clean install (wipe all existing data)
# docker volume rm custom_postgresql-data
# OR_ADMIN_PASSWORD=secret OR_HOSTNAME=my.domain.com docker-compose -p custom up -d
# All data is kept in volumes. Create a backup of the volumes to preserve data.
version: "3.9"
proxy-data:
deployment-data:
postgresql-data:
manager-data:
# Add an NFS volume to the stack
# efs-data:
# driver: local
# driver_opts:
# type: nfs
# o: "addr=${EFS_DNS?DNS must be set to mount NFS volume},rw,nfsvers=4.1,rsize=1048576,wsize=1048576,hard,timeo=600,retrans=2,noresvport"
# device: ":/"
x-logging: &awslogs
logging:
driver: awslogs
options:
awslogs-region: ${AWS_REGION:-eu-west-1}
awslogs-group: ${OR_HOSTNAME}
awslogs-create-group: "true"
tag: "{{.Name}}/{{.ID}}"
services:
# This service will only populate an empty volume on startup and then exit.
# If the volume already contains data, it exits immediately.
deployment:
image: openremote/deployment:${DEPLOYMENT_VERSION:-latest}
- deployment-data:/deployment
proxy:
restart: always
depends_on:
manager:
condition: service_healthy
ports:
- "80:80"
- "443:443"
- "8883:8883"
- "1883:1883"
- proxy-data:/deployment
- deployment-data:/data
LE_EMAIL: ${OR_EMAIL_ADMIN}
DOMAINNAME: ${OR_HOSTNAME:-0.0.0.0}
# USE A CUSTOM PROXY CONFIG - COPY FROM https://github.com/openremote/proxy/blob/main/haproxy.cfg
<<: *awslogs
postgresql:
restart: always
- manager-data:/storage
<<: *awslogs
keycloak:
restart: always
depends_on:
postgresql:
KEYCLOAK_ADMIN_PASSWORD: ${OR_ADMIN_PASSWORD:-admin}
<<: *awslogs
manager:
# image: openremote/manager:${MANAGER_VERSION:-latest}
image: openremote/manager:latest
# image: openremote/manager:manhv3
restart: always
depends_on:
keycloak:
# Map data should be accessed from a volume mount
# 1). Host filesystem - /deployment.local:/deployment.local
# 2) NFS/EFS network mount - efs-data:/efs
# Here are some typical environment variables you want to set
# see openremote/profile/deploy.yml for details
OR_ADMIN_PASSWORD: ${OR_ADMIN_PASSWORD:-admin}
OR_SETUP_TYPE: # Typical values to support are staging and production
OR_SETUP_RUN_ON_RESTART:
OR_EMAIL_HOST: smtp.gmail.com
OR_EMAIL_USER: ngmdang1306@gmail.com
OR_EMAIL_PASSWORD: ****************
OR_EMAIL_X_HEADERS:
OR_EMAIL_FROM: ngmdang1306@gmail.com
OR_EMAIL_ADMIN:
OR_HOSTNAME: ${OR_HOSTNAME:-0.0.0.0}
OR_MAP_TILES_PATH: "/efs/europe.mbtiles"
#OR_MAP_TILES_PATH: '/efs/europe.mbtiles'
<<: *awslogs
And then i run : docker-compose down
docker-compose up -d
and it’s doesn’t seem to work .
I have this error in terminal :
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Try the new cross-platform PowerShell https://aka.ms/pscore6
PS C:\Users\dangd\iotplatform\iotplatform> docker-compose down
time="2025-05-12T10:51:27+07:00" level=warning msg="The \"OR_HOSTNAME\" variable is not set. Defaulting to a blank string."
time="2025-05-12T10:51:27+07:00" level=warning msg="The \"OR_EMAIL_ADMIN\" variable is not set. Defaulting to a blank string."
time="2025-05-12T10:51:27+07:00" level=warning msg="C:\\Users\\dangd\\iotplatform\\iotplatform\\docker-compose.yml: the attribute `version` is obsolete, it will be ignored, please remove it to avoid potential confusion"
PS C:\Users\dangd\iotplatform\iotplatform> docker-compose up -d
time="2025-05-12T10:51:28+07:00" level=warning msg="The \"OR_EMAIL_ADMIN\" variable is not set. Defaulting to a blank string."
time="2025-05-12T10:51:28+07:00" level=warning msg="The \"OR_HOSTNAME\" variable is not set. Defaulting to a blank string."
time="2025-05-12T10:51:28+07:00" level=warning msg="C:\\Users\\dangd\\iotplatform\\iotplatform\\docker-compose.yml: the attribute `version` is obsolete, it will be ignored, please remove it to avoid potential confusion"
[+] Running 1/1
✘ deployment Error pull access denied for openremote/deployment, repository does not exist or may require 'docker login' 1.8s
Error response from daemon: pull access denied for openremote/deployment, repository does not exist or may require 'docker login'
