Hi, thank you for your prompt reply.
After running docker desktop and running docker-compose -p test5 -f profile/dev-proxy.yml up --build -d in the terminal, and the postgresql, proxy, and keycloak were created successfully.
After running ‘Empty’, the results were
“Webserver ready on http://0.0.0.0:8080”
“>>> Runtime container startup complete”
In my docker, the manager is missing while the rest are there (proxy, postgresql, and keycloak). Local host could not be accessed. However, I am not sure how to create the manager. Please assist. Thank you.
The dev-proxy profile is for running the manager in an IDE behind the proxy container and you would use the Empty with Proxy run configuration in that scenario.
What is it you are trying to do exactly?
As @Don mentioned you generally use the dev-testing profile for manager development work in an IDE and then if you want to use the manager UI during development you will need to use the following commands:
cd ui/app/manager
npm run serve
The manager UI can then be accessed at http://localhost:9000/manager/
