The error you are seeing is caused by the fact docker-compose is trying to first build the required images. You can pull the images from docker hub (docker-compose pull):
They are quite out of date though (I will try and find time to push newer images hopefully Wednesday) so for now you would be better off building them; to do that, you should be able to type:
./gradlew clean installDist
After that you can run the docker-compose command you were trying.
hey Richard,
that’s very kind of you. Thank you for finding time to reply, your suggestion indeed helped me with the installation. Appreciate the intellect and the quality of answer.
In fact currently the images are pretty up to date, as they are build automatically with our CI/CD pipeline and pushed to the hub.docker.com. Therefore if you see this error simply create an empty directory:
