Hi ,
I setup openremote on IDE. I have succesfully tested data communicating from MQTT Exoplorer to openremote. Here I use unsecure communication with 1883 poprt(Mqtt Explorer TLS =OFF, SSL =OFF).
Now I tried to send data from Pythone code Paho to openremote but it give some error.
Code:
import paho.mqtt.client as mqtt
import time
import certifi
import ssl
import json
import requests
from requests import *
def on_connect(client, userdata, flags, rc):
if rc == 0:
print(“Connected to broker”)
global Connected # Use global variable
Connected = True # Signal connection
else:
print(“Connection failed”)
def on_publish(client, userdata, result):
print(f’Data published. Data: {attribute_value}')
pass
def on_message(client, userdata, message):
msg = json.loads(message.payload.decode(“utf-8”))
id = msg[“attributeState”][“ref”][“id”]
att_name = msg[“attributeState”][“ref”][“name”]
att_value = msg[“attributeState”][“value”]
print(f’Message received. Asset ID: {id}. Attribute name: {att_name}. Attribute value: {att_value}')
Connected = False
username = “master:mqttuser”
secret = “Q3XdkI47UzePlgQGyIxGGuSsbHfni26s”
host = “192.168.11.217”
port = 1883
clientID = ‘client12345’
assetID = ‘585TvXai66JeXi07w1LZVK’
attributeWr = ‘writeAttribute’
attributeRd = ‘subscribeAttribute’
clientMQTT = mqtt.Client(clientID)
clientMQTT.username_pw_set(username, password=secret)
the key steps here
context = ssl.SSLContext(ssl.PROTOCOL_TLSv1_2)
if you do not want to check the cert hostname, skip it
context.check_hostname = False
clientMQTT.tls_set_context(context)
response = requests.get(“http://192.168.11.217:1883”, verify=False)
clientMQTT.on_connect = on_connect
clientMQTT.on_publish = on_publish
clientMQTT.on_message = on_message
clientMQTT.connect(host, port=port)
clientMQTT.loop_start()
while Connected != True:
time.sleep(10)
attribute_value = 10
i = 0
for i in range(attribute_value):
clientMQTT.publish(f"master/{clientID}/writeattributevalue/{attributeWr}/{assetID}", i)
time.sleep(1)
time.sleep(5)
clientMQTT.disconnect()
clientMQTT.loop_stop()
we have tried to off/disable TLS, SSL but we have tried that method is correct or not we have doubt.
Connection established but data not send
Shresth
