I’m new to OpenRemote, and I manage to link and get MQTT events from it. ![]()
The issue is, when I try to publish an attribute value I’m always getting this error:
manager_1 | 2023-02-10 09:16:54.359 ERROR [Thread-1 (ActiveMQ-serve..595)] ache.activemq.artemis.core.protocol.mqtt : AMQ834002: Error processing control packet: MqttPublishMessage[fixedHeader=MqttFixedHeader[messageType=PUBLISH, isDup=false, qosLevel=AT_MOST_ONCE, isRetain=false, remainingLength=161], variableHeader=MqttPublishVariableHeader[topicName=master/test_mqtt/attribute/position/7A92oxiVkatOShs7pu7QUL, packetId=-1], payload=PooledSlicedByteBuf(ridx: 0, widx: 101, cap: 101/101, unwrapped: PooledUnsafeDirectByteBuf(ridx: 164, widx: 164, cap: 1024))]
manager_1 | ActiveMQSecurityException[errorType=SECURITY_EXCEPTION message=AMQ229032: User: master:dil1 does not have permission='SEND' on address master.test_mqtt.attribute.position.7A92oxiVkatOShs7pu7QUL]
manager_1 | at org.apache.activemq.artemis.core.security.impl.SecurityStoreImpl.check(SecurityStoreImpl.java:289)
manager_1 | at org.apache.activemq.artemis.core.server.impl.ServerSessionImpl.securityCheck(ServerSessionImpl.java:502)
manager_1 | at org.apache.activemq.artemis.core.server.impl.ServerSessionImpl.doSend(ServerSessionImpl.java:2212)
manager_1 | at org.apache.activemq.artemis.core.server.impl.ServerSessionImpl.send(ServerSessionImpl.java:1840)
manager_1 | at org.apache.activemq.artemis.core.server.impl.ServerSessionImpl.send(ServerSessionImpl.java:1781)
manager_1 | at org.apache.activemq.artemis.core.protocol.mqtt.MQTTPublishManager.sendToQueue(MQTTPublishManager.java:217)
manager_1 | at org.apache.activemq.artemis.core.protocol.mqtt.MQTTProtocolHandler.handlePublish(MQTTProtocolHandler.java:317)
manager_1 | at org.apache.activemq.artemis.core.protocol.mqtt.MQTTProtocolHandler.act(MQTTProtocolHandler.java:160)
manager_1 | at org.apache.activemq.artemis.utils.actors.Actor.doTask(Actor.java:33)
manager_1 | at org.apache.activemq.artemis.utils.actors.ProcessorBase.executePendingTasks(ProcessorBase.java:67)
manager_1 | at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
manager_1 | at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
manager_1 | at org.apache.activemq.artemis.utils.ActiveMQThreadFactory$1.run(ActiveMQThreadFactory.java:118)
This is my Agent and Asset configuration:
This is what I try to submit to the Asset:
Tpoic: master/test_mqtt/attribute/position/7A92oxiVkatOShs7pu7QUL
Value:
"type": "boolean",
"value": false,
"name": "position",
"meta": {
"readOnly": true
Any idea why I’m getting this error?
