Hello All,
I open this ticket because I have a problem with a Fibaro FG223 (Double swtich)
My configuration is the following
Raspberry PI 3
Raspbian Strech
AEOTEC ZW90 Z-Stick Gen 5
the problem I have is that I don t have any xml file generated in the folder webapps/controller/zwave
I have already one socket registered and I can manage it with Openremote (ID=3)
When I check the file zwave.log I can see that there s a dialogue with a device which has the ID=4.
I guess it is my Fibaro FGS223 so it seems that the association with the USB stock is OK.
So because I don t the xml file I cannot manage my switch in openremote.
What should I do ?
Thanks a lot for your help
Regards,
Jerome
Here a part of my zwave.log :
DEBUG 2017-11-05 17:10:49,511 (Z-Wave): Node_Initializer : DEBUG 2017-11-05 17:10:49,511 (Z-Wave): Node_Initializer : Node ‘4’ : [COMMAND_CLASS_VERSION::VERSION_COMMAND_CLASS_REPORT (Retry=‘1’), CommandClass=‘COMMAND_CLASS_SWITCH_MULTILEVEL’, Version=‘3’].
DEBUG 2017-11-05 17:10:49,546 (Z-Wave): Node_Initializer : Node ‘4’ : All command class versions of the root device have been updated.
DEBUG 2017-11-05 17:10:49,547 (Z-Wave): Node_Initializer : Node ‘4’ : [COMMAND_CLASS_VERSION::VERSION_GET (Retry=‘1’)]…
DEBUG 2017-11-05 17:10:49,557 (Z-Wave): Controller_API : Dequeue (queue count=0) Z-Wave function call ‘ZW_SendData(NodeID=4, Payload=[0x86, 0x11], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2017-11-05 17:10:49,557 (Z-Wave): Controller_API : Enqueue (queue count=1) Z-Wave function call ‘ZW_SendData(NodeID=4, Payload=[0x86, 0x11], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2017-11-05 17:10:49,557 (Z-Wave): TX_Session_Layer : Executing Z-Wave function call ‘ZW_SendData(NodeID=4, Payload=[0x86, 0x11], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’…
DEBUG 2017-11-05 17:10:49,558 (Z-Wave): TX_Session_Layer : Send (repeat count=1) Z-Wave function ‘ZW_SendData(NodeID=4, Payload=[0x86, 0x11], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x17)’ request (callback ID=0x17).
DEBUG 2017-11-05 17:10:49,559 (Z-Wave): TX_Frame_Layer : Send data frame [0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x86, 0x11, 0x05, 0x17, 0x66].
DEBUG 2017-11-05 17:10:49,562 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x06]
DEBUG 2017-11-05 17:10:49,563 (Z-Wave): RX_Frame_Layer : ACK -> Data frame [0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x86, 0x11, 0x05, 0x17, 0x66] transmission OK.
DEBUG 2017-11-05 17:10:49,564 (Z-Wave): RX_Session_Layer : ACK -> Z-Wave function ‘ZW_SendData(NodeID=4, Payload=[0x86, 0x11], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x17)’ has been successfully sent - waiting 5 000 [ms] for response frame.
DEBUG 2017-11-05 17:10:49,567 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2017-11-05 17:10:49,568 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x04, 0x01, 0x13, 0x01, 0xE8]
DEBUG 2017-11-05 17:10:49,569 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] has been received.
DEBUG 2017-11-05 17:10:49,569 (Z-Wave): RX_Session_Layer : ‘ZW_SendData’ response [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] with status ‘RETURN_VALUE_TRUE’ received (callback ID=0x17).
DEBUG 2017-11-05 17:10:49,570 (Z-Wave): RX_Session_Layer : Waiting 64 988 [ms] for ‘ZW_SendData’ callback frame (callback ID=0x17).
DEBUG 2017-11-05 17:10:49,587 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2017-11-05 17:10:49,588 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x07, 0x00, 0x13, 0x17, 0x00, 0x00, 0x03, 0xFF]
DEBUG 2017-11-05 17:10:49,589 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x07, 0x00, 0x13, 0x17, 0x00, 0x00, 0x03, 0xFF] has been received.
DEBUG 2017-11-05 17:10:49,589 (Z-Wave): RX_Session_Layer : Callback [0x01, 0x07, 0x00, 0x13, 0x17, 0x00, 0x00, 0x03, 0xFF] (callback ID=0x17) with state ‘TRANSMIT_COMPLETE_OK’ received -> Z-Wave function ‘ZW_SendData(NodeID=4, Payload=[0x86, 0x11], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x17)’ successfully executed.
DEBUG 2017-11-05 17:10:49,603 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2017-11-05 17:10:49,604 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x0F, 0x00, 0x04, 0x00, 0x04, 0x09, 0x86, 0x12, 0x03, 0x04, 0x05, 0x03, 0x02, 0x03, 0x00, 0x6D]
DEBUG 2017-11-05 17:10:49,604 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x0F, 0x00, 0x04, 0x00, 0x04, 0x09, 0x86, 0x12, 0x03, 0x04, 0x05, 0x03, 0x02, 0x03, 0x00, 0x6D] has been received.
DEBUG 2017-11-05 17:10:49,609 (Z-Wave): Node_Initializer : Node ‘4’ : [COMMAND_CLASS_VERSION::VERSION_REPORT (Retry=‘1’), ZWaveLibType=‘ZW_LIB_SLAVE_ENHANCED’, SDKVersion=‘SDK_VERSION_UNKNOWN’, AppVersion=‘3.2’].
DEBUG 2017-11-05 17:10:49,610 (Z-Wave): Node_Initializer : Node ‘4’ : [COMMAND_CLASS_MANUFACTURER_SPECIFIC::MANUFACTURER_SPECIFIC_GET (Retry=‘1’)]…
DEBUG 2017-11-05 17:10:49,617 (Z-Wave): Controller_API : Dequeue (queue count=0) Z-Wave function call ‘ZW_SendData(NodeID=4, Payload=[0x72, 0x04], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2017-11-05 17:10:49,617 (Z-Wave): Controller_API : Enqueue (queue count=1) Z-Wave function call ‘ZW_SendData(NodeID=4, Payload=[0x72, 0x04], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2017-11-05 17:10:49,617 (Z-Wave): TX_Session_Layer : Executing Z-Wave function call ‘ZW_SendData(NodeID=4, Payload=[0x72, 0x04], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’…
DEBUG 2017-11-05 17:10:49,618 (Z-Wave): TX_Session_Layer : Send (repeat count=1) Z-Wave function ‘ZW_SendData(NodeID=4, Payload=[0x72, 0x04], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x18)’ request (callback ID=0x18).
DEBUG 2017-11-05 17:10:49,618 (Z-Wave): TX_Frame_Layer : Send data frame [0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x72, 0x04, 0x05, 0x18, 0x88].
DEBUG 2017-11-05 17:10:49,621 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x06]
DEBUG 2017-11-05 17:10:49,622 (Z-Wave): RX_Frame_Layer : ACK -> Data frame [0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x72, 0x04, 0x05, 0x18, 0x88] transmission OK.
DEBUG 2017-11-05 17:10:49,622 (Z-Wave): RX_Session_Layer : ACK -> Z-Wave function ‘ZW_SendData(NodeID=4, Payload=[0x72, 0x04], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x18)’ has been successfully sent - waiting 5 000 [ms] for response frame.
DEBUG 2017-11-05 17:10:49,626 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2017-11-05 17:10:49,627 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x04, 0x01, 0x13, 0x01, 0xE8]
DEBUG 2017-11-05 17:10:49,628 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] has been received.
DEBUG 2017-11-05 17:10:49,628 (Z-Wave): RX_Session_Layer : ‘ZW_SendData’ response [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] with status ‘RETURN_VALUE_TRUE’ received (callback ID=0x18).
DEBUG 2017-11-05 17:10:49,629 (Z-Wave): RX_Session_Layer : Waiting 64 989 [ms] for ‘ZW_SendData’ callback frame (callback ID=0x18).
DEBUG 2017-11-05 17:10:49,648 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2017-11-05 17:10:49,649 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x07, 0x00, 0x13, 0x18, 0x00, 0x00, 0x03, 0xF0]
DEBUG 2017-11-05 17:10:49,650 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x07, 0x00, 0x13, 0x18, 0x00, 0x00, 0x03, 0xF0] has been received.
DEBUG 2017-11-05 17:10:49,650 (Z-Wave): RX_Session_Layer : Callback [0x01, 0x07, 0x00, 0x13, 0x18, 0x00, 0x00, 0x03, 0xF0] (callback ID=0x18) with state ‘TRANSMIT_COMPLETE_OK’ received -> Z-Wave function ‘ZW_SendData(NodeID=4, Payload=[0x72, 0x04], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x18)’ successfully executed.
DEBUG 2017-11-05 17:10:49,662 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2017-11-05 17:10:49,663 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x0E, 0x00, 0x04, 0x00, 0x04, 0x08, 0x72, 0x05, 0x01, 0x0F, 0x02, 0x03, 0x10, 0x00, 0x91]
DEBUG 2017-11-05 17:10:49,663 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x0E, 0x00, 0x04, 0x00, 0x04, 0x08, 0x72, 0x05, 0x01, 0x0F, 0x02, 0x03, 0x10, 0x00, 0x91] has been received.
DEBUG 2017-11-05 17:10:49,668 (Z-Wave): Node_Initializer : Node ‘4’ : [COMMAND_CLASS_MANUFACTURER_SPECIFIC::MANUFACTURER_SPECIFIC_REPORT (Retry=‘1’), Manufacturer=‘Fibargroup’, ProductTypeID=‘0x0203’, ProductID=‘0x1000’].
DEBUG 2017-11-05 17:10:49,668 (Z-Wave): Node_Initializer : Node ‘4’ : Configure parameters…
DEBUG 2017-11-05 17:10:49,677 (Z-Wave): Node_Initializer : Node ‘4’ : Requesting multi channel info…
DEBUG 2017-11-05 17:10:49,677 (Z-Wave): Node_Initializer : Node ‘4’ : [COMMAND_CLASS_MULTI_CHANNEL_V2::MULTI_CHANNEL_END_POINT_GET (Retry=‘1’)]…
DEBUG 2017-11-05 17:10:49,683 (Z-Wave): Controller_API : Enqueue (queue count=1) Z-Wave function call ‘ZW_SendData(NodeID=4, Payload=[0x60, 0x07], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2017-11-05 17:10:49,683 (Z-Wave): Controller_API : Dequeue (queue count=0) Z-Wave function call ‘ZW_SendData(NodeID=4, Payload=[0x60, 0x07], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2017-11-05 17:10:49,684 (Z-Wave): TX_Session_Layer : Executing Z-Wave function call ‘ZW_SendData(NodeID=4, Payload=[0x60, 0x07], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’…
DEBUG 2017-11-05 17:10:49,684 (Z-Wave): TX_Session_Layer : Send (repeat count=1) Z-Wave function ‘ZW_SendData(NodeID=4, Payload=[0x60, 0x07], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x19)’ request (callback ID=0x19).
DEBUG 2017-11-05 17:10:49,684 (Z-Wave): TX_Frame_Layer : Send data frame [0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x60, 0x07, 0x05, 0x19, 0x98].
DEBUG 2017-11-05 17:10:49,687 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x06]
DEBUG 2017-11-05 17:10:49,687 (Z-Wave): RX_Frame_Layer : ACK -> Data frame [0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x60, 0x07, 0x05, 0x19, 0x98] transmission OK.
DEBUG 2017-11-05 17:10:49,688 (Z-Wave): RX_Session_Layer : ACK -> Z-Wave function ‘ZW_SendData(NodeID=4, Payload=[0x60, 0x07], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x19)’ has been successfully sent - waiting 5 000 [ms] for response frame.
DEBUG 2017-11-05 17:10:49,692 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2017-11-05 17:10:49,692 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x04, 0x01, 0x13, 0x01, 0xE8]
DEBUG 2017-11-05 17:10:49,693 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] has been received.
DEBUG 2017-11-05 17:10:49,693 (Z-Wave): RX_Session_Layer : ‘ZW_SendData’ response [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] with status ‘RETURN_VALUE_TRUE’ received (callback ID=0x19).
DEBUG 2017-11-05 17:10:49,693 (Z-Wave): RX_Session_Layer : Waiting 64 991 [ms] for ‘ZW_SendData’ callback frame (callback ID=0x19).
DEBUG 2017-11-05 17:10:49,712 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2017-11-05 17:10:49,713 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x07, 0x00, 0x13, 0x19, 0x00, 0x00, 0x02, 0xF0]
DEBUG 2017-11-05 17:10:49,713 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x07, 0x00, 0x13, 0x19, 0x00, 0x00, 0x02, 0xF0] has been received.
DEBUG 2017-11-05 17:10:49,714 (Z-Wave): RX_Session_Layer : Callback [0x01, 0x07, 0x00, 0x13, 0x19, 0x00, 0x00, 0x02, 0xF0] (callback ID=0x19) with state ‘TRANSMIT_COMPLETE_OK’ received -> Z-Wave function ‘ZW_SendData(NodeID=4, Payload=[0x60, 0x07], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x19)’ successfully executed.
DEBUG 2017-11-05 17:10:49,726 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2017-11-05 17:10:49,727 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x0B, 0x00, 0x04, 0x00, 0x04, 0x05, 0x60, 0x08, 0x40, 0x02, 0x00, 0xDB]
DEBUG 2017-11-05 17:10:49,728 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x0B, 0x00, 0x04, 0x00, 0x04, 0x05, 0x60, 0x08, 0x40, 0x02, 0x00, 0xDB] has been received.
DEBUG 2017-11-05 17:10:49,732 (Z-Wave): Node_Initializer : Node ‘4’ : [COMMAND_CLASS_MULTI_CHANNEL_V2::MULTI_CHANNEL_END_POINT_REPORT (Retry=‘1’), EndPoints=‘2’, Identical=‘YES’, Dynamic=‘NO’]
DEBUG 2017-11-05 17:10:49,735 (Z-Wave): Node_Initializer : Node ‘4’ : [COMMAND_CLASS_MULTI_CHANNEL_V2::MULTI_CHANNEL_CAPABILITY_GET (Retry=‘1’), EndPoint=‘1’]
DEBUG 2017-11-05 17:10:49,742 (Z-Wave): Controller_API : Dequeue (queue count=0) Z-Wave function call ‘ZW_SendData(NodeID=4, Payload=[0x60, 0x09, 0x01], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2017-11-05 17:10:49,742 (Z-Wave): Controller_API : Enqueue (queue count=1) Z-Wave function call ‘ZW_SendData(NodeID=4, Payload=[0x60, 0x09, 0x01], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2017-11-05 17:10:49,742 (Z-Wave): TX_Session_Layer : Executing Z-Wave function call ‘ZW_SendData(NodeID=4, Payload=[0x60, 0x09, 0x01], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’…
DEBUG 2017-11-05 17:10:49,742 (Z-Wave): TX_Session_Layer : Send (repeat count=1) Z-Wave function ‘ZW_SendData(NodeID=4, Payload=[0x60, 0x09, 0x01], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x1A)’ request (callback ID=0x1A).
DEBUG 2017-11-05 17:10:49,743 (Z-Wave): TX_Frame_Layer : Send data frame [0x01, 0x0A, 0x00, 0x13, 0x04, 0x03, 0x60, 0x09, 0x01, 0x05, 0x1A, 0x96].
DEBUG 2017-11-05 17:10:49,745 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x06]
DEBUG 2017-11-05 17:10:49,746 (Z-Wave): RX_Frame_Layer : ACK -> Data frame [0x01, 0x0A, 0x00, 0x13, 0x04, 0x03, 0x60, 0x09, 0x01, 0x05, 0x1A, 0x96] transmission OK.
DEBUG 2017-11-05 17:10:49,746 (Z-Wave): RX_Session_Layer : ACK -> Z-Wave function ‘ZW_SendData(NodeID=4, Payload=[0x60, 0x09, 0x01], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x1A)’ has been successfully sent - waiting 5 000 [ms] for response frame.
DEBUG 2017-11-05 17:10:49,752 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2017-11-05 17:10:49,752 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x04, 0x01, 0x13, 0x01, 0xE8]
DEBUG 2017-11-05 17:10:49,753 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] has been received.
DEBUG 2017-11-05 17:10:49,753 (Z-Wave): RX_Session_Layer : ‘ZW_SendData’ response [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] with status ‘RETURN_VALUE_TRUE’ received (callback ID=0x1A).
DEBUG 2017-11-05 17:10:49,753 (Z-Wave): RX_Session_Layer : Waiting 64 989 [ms] for ‘ZW_SendData’ callback frame (callback ID=0x1A).
DEBUG 2017-11-05 17:10:49,772 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2017-11-05 17:10:49,772 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x07, 0x00, 0x13, 0x1A, 0x00, 0x00, 0x02, 0xF3]
DEBUG 2017-11-05 17:10:49,773 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x07, 0x00, 0x13, 0x1A, 0x00, 0x00, 0x02, 0xF3] has been received.
DEBUG 2017-11-05 17:10:49,773 (Z-Wave): RX_Session_Layer : Callback [0x01, 0x07, 0x00, 0x13, 0x1A, 0x00, 0x00, 0x02, 0xF3] (callback ID=0x1A) with state ‘TRANSMIT_COMPLETE_OK’ received -> Z-Wave function ‘ZW_SendData(NodeID=4, Payload=[0x60, 0x09, 0x01], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x1A)’ successfully executed.
DEBUG 2017-11-05 17:10:49,788 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2017-11-05 17:10:49,789 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x04, 0x0E, 0x60, 0x0A, 0x01, 0x10, 0x01, 0x5E, 0x86, 0x25, 0x85, 0x59, 0x8E, 0x32, 0xEF, 0x26, 0xCB]
DEBUG 2017-11-05 17:10:49,790 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x04, 0x0E, 0x60, 0x0A, 0x01, 0x10, 0x01, 0x5E, 0x86, 0x25, 0x85, 0x59, 0x8E, 0x32, 0xEF, 0x26, 0xCB] has been received.
DEBUG 2017-11-05 17:10:49,795 (Z-Wave): Node_Initializer : Node ‘4’ : [COMMAND_CLASS_MULTI_CHANNEL_V2::MULTI_CHANNEL_CAPABILITY_REPORT (Retry=‘1’), EndPoint=‘1’, Generic=‘GENERIC_TYPE_SWITCH_BINARY’, Specific=‘SPECIFIC_TYPE_POWER_SWITCH_BINARY’, SupportedClasses : [COMMAND_CLASS_ZWAVEPLUS_INFO, COMMAND_CLASS_VERSION, COMMAND_CLASS_SWITCH_BINARY, COMMAND_CLASS_ASSOCIATION, COMMAND_CLASS_ASSOCIATION_GRP_INFO, COMMAND_CLASS_MULTI_INSTANCE_ASSOCIATION, COMMAND_CLASS_METER, COMMAND_CLASS_MARK, COMMAND_CLASS_SWITCH_MULTILEVEL], Dynamic=‘false’]
DEBUG 2017-11-05 17:10:49,796 (Z-Wave): Node_Initializer : Node ‘4:1’ : [COMMAND_CLASS_SECURITY::SECURITY_COMMAND_SUPPORTED_GET]
DEBUG 2017-11-05 17:11:05,211 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2017-11-05 17:11:05,212 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x10, 0x00, 0x04, 0x00, 0x03, 0x0A, 0x32, 0x02, 0x21, 0x74, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x87]
DEBUG 2017-11-05 17:11:05,214 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x10, 0x00, 0x04, 0x00, 0x03, 0x0A, 0x32, 0x02, 0x21, 0x74, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x87] has been received.
DEBUG 2017-11-05 17:11:05,215 (Z-Wave): RX_Session_Layer : Node ‘3’ : [APP_CMD_HANDLER_FRAME : NodeID=‘3’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0x21, 0x74, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
