FMC650 MQTT connection rejected by OpenRemote – unexpected broker/IMEI username
I’m trying to use the OpenRemote Fleet Management setup with Teltonika FMC650 devices, following the tutorial for the FMC003.
The FMC003 works correctly, but the FMC650 is rejected by the MQTT broker.
The FMC650 is configured as follows:
  • Firmware: 03.01.01.Rev.15
  • MQTT Client Type: AWS IoT Custom
  • Device ID: empty
  • Data Topic: xxx/FMC650Test/teltonika/%imei%/data
  • Commands Topic: xxx/FMC650Test/teltonika/%imei%/commands
  • Only the root CA certificate is configured, same as on the working FMC003
I captured the MQTT CONNECT packet on the OpenRemote Docker network. The FMC650 sends:
Client ID: <IMEI>
Username:  x.x.de/<IMEI>
Password:  empty
For example:
Client ID: 862xxxx6159
Username:  x.x.de/862xxxx6159
The CONNECT flags are 0xC2, so username and password are explicitly present.
OpenRemote then immediately responds with:
20 02 00 05
which is MQTT 3.1.1 CONNACK: Connection refused - Not authorized, and the connection is closed.
This happens consistently with two different FMC650 devices.
The FMC003, using the same general OpenRemote setup, works correctly. My suspicion is that the FMC650’s newer AWS IoT Custom MQTT implementation automatically generates the username <broker hostname>/<IMEI>, while the OpenRemote Teltonika MQTT handling expects the Teltonika connection to be anonymous.
The FMC650 never reaches the publish/subscribe stage, so the configured data and command topics do not seem to be the immediate problem.
Have you encountered this behavior with FMC650 devices before? Would it make sense to adjust the OpenRemote Teltonika MQTT authentication handling so that an FMC650 connection with:
Client ID = IMEI
Username  = <broker>/<IMEI>
Password  = empty
can be treated similarly to the anonymous Teltonika connection used by the FMC003?
I can also provide the full tcpdump/hex capture if useful.
Hey @Ankou ,
Thanks for your post! That’s exactly what’s happening most probably, we assume Teltonika devices that connect to OpenRemote do so via anonymous connections, and connections that do have a username but an incorrect password are kicked out.
not sure how we missed this update, but I will take a look soon. At the same time, my mTLS PR ( MQTT Broker: authenticate connections from client certificates by pankalog · Pull Request #3203 · openremote/openremote · GitHub ) would solve this, and the new fleet telematics architecture changes coming up would make this vastly easier to manage.
Thanks for trying out OpenRemote, let me know if anything else comes up!
I guess that password is empty not null when ActiveMQORSecurityManager.authenticate() is hit.
We could change if (password == null) to if (TextUtil.isNullOrEmpty(password))
Thank you for your response.
The issue lies on the side of Openremote correct?
How long would your fix take? If it would take a longer time we are thinking about building a sanitizer to “cut out” that piece.
Another question regarding the fleet management feature.
We are currently running the containers: proxy latest, keykloack latest and manager 1.15. 1
Openremote core is running on 1.28,correct?
Is that maybe an issue or is that intended,that the fleet management runs on 1.15.1
Hey @Ankou ,
It’s not quite an “OpenRemote” issue, it’s just that we weren’t aware of Teltonika’s MQTT client changes :sweat_smile:
I have opened a PR to allow the devices to connect: Fix anonymous MQTT authentication with empty passwords by pankalog · Pull Request #3244 · openremote/openremote · GitHub
Once that is merged to the main OpenRemote repository, I will be updating fleet-management to the latest OpenRemote version to make sure the changes are implemented. You’d just be pulling the new container images to get the newest OpenRemote version. I’ll also reply here to let you know when that happens.
Again, thanks for letting us know of the issue!
Good afternoon @Ankou ,
I’ve created a new fleet management release! It includes the fix you mentioned. Make sure to read the release notes.
Thanks for letting me know of the issue, let me know if it’s still there.
