Freelancer to install and configure OpenRemote with MQTT and Keycloak
Hello, is there anyone here who can help me - for a fee - to complete my OpenRemote installation with MQTT?
What do you need exactly?
Hello Paco
I rented a server from Hetzner and installed Docker with Open Remote there. Without intensive help from Chatgpt I would not have succeeded… - well - now it can be reached and runs…
Now I wanted to activate the MQTT Broker because I want to transport data from a SCADA system (Fernhill) to OpenRemote.
I have tried using the documentation - but have failed to activate the MQTT broker in OpenRemote.
According to ChatGPT, I now lack admin rights on keycloak…
I simply don’t have time to try for long, especially as other adjustments such as a different map section, customers, assets assigned to customers are also pending.
At the end of the day, I need a stable, functioning solution where my customers can see their data. Possibly also certain data that we want to make available to the general public.
I expect to have 50 customers over the next 2 years.
What do you mean?
Do you have the time and inclination to support me with this project?
we have OR running on our own server and receive data via MQTT from 2 or 3 sources. It’s quite simple, just set up an MQTT agent, and then inside your asset, in each attribute you want to receive, use ‘Agent link’ and your MQTTAgentLink. I think that’s what you need, to receive MQTT data, isn’t it? So I guess you should have the information from your SCADA to get MQTT data.
I’d even recommend using software such as MQTT Explorer to test the data.
On the other hand I find it strange that you don’t have administrator permissions having created the containers from docker, at least with the user ‘admin’ and the password you have defined. Can’t you see it in ‘www.yourdomain.xxx/auth’?
Interested in this also.
Dear
I can help
koleyapurba007@gmail.com
Hey Apurba, I emailed you about two weeks ago - no response. Send me a DM please, thanks.
sorry for late reply.
i just mal back to you pls check.
@rkeller how to install openremote on Hetzner? I got some troubles which i think are not solved. thx
