I am back with a question. I worked throughout the months on my Velbus / Openremote system with a Beaglebone Black.
Al working fine, untill August 14th.
The rules that I used to send mail if a certain sensor changed always worked, and now stopped working on the 14th.
See the code that I used below.
I was wondering if you know the solution how to fix this, and what I can do to further analyse the problem?
What I have.
well the rules are below
but I did not change them before, on or after the 14th.
I did do an syncronization with the server on the 14th
But I only added a lot in UI designer and a bit in Building Modeler/Devices
I believe I did not change any command or sensors related to the mail rules.
And I have 2 seperate Mail rules, and they are both not working
Everything else seems to work fine, including the fysical and virtual sensors related to this mail.
and the linkage with velbus system, the internet and the power cable seem to work.
the gmail did not send the mail
In the logs of Boot, Rules en Velbus I don’t see anything different except for this sentence in Boot.log
INFO 2018-08-26 11:17:14,152 : Controller Definition File Watcher for Default Deployer started.
This is said on synchronization since the first syncronization on the 14th.
I tried to:
use old back up rules, and syncronize againg
power on and off on the server
Anybody has an idea?
Or maybe want you need to know more to have a solution?
Thanks!
Richard
rule “Aanzetten Mail Deur Open - Keuken zijraam”
when
Event( source == “051_04_SE_ST_KeukenZijDicht”, value == “released” )
then
execute.command(“050_0x_EON_keukenmail”);
System.out.println(“Aanzetten Mail Deur Open - Keuken zijraam”);
end
rule “Verzenden Mail KeukenDeur Open”
when
Switch ( source == “050_0x_ESensor_keukenmail”, value == “on”)
then
execute.command (“050_0x_EOFF_keukenmail”);
final String username="exampleA@gmail.com";
final String password = “password”;
Properties props = new Properties();
props.put(“mail.smtp.host”,“smtp.gmail.com”);
props.put(“mail.smtp.socketFactory.port”,“465”);
props.put(“mail.smtp.socketFactory.class”,“javax.net.ssl.SSLSocketFactory”);
props.put(“mail.smtp.auth”,“true”);
props.put(“mail.smtp.port”,“465”);
Session session = Session.getInstance(props,
new javax.mail.Authenticator() {
protected PasswordAuthentication getPasswordAuthentication() {
return new PasswordAuthentication(username, password);
try {
Message message = new MimeMessage(session);
message.setFrom(new InternetAddress(“exampleA@gmail.com”));
message.setRecipients(Message.RecipientType.TO,
InternetAddress.parse(“exampleB@hotmail.com”));
message.setSubject(“Zij Keukenraam gaat open”);
message.setText(“Het raam aan de zijkant van de keuken gaat open.”);
Transport.send(message);
System.out.println(“Er gaat een deur open.keuken”);
} catch (MessagingException e) {
throw new RuntimeException(e);
end
