ndt080
February 26, 2024, 6:20pm
1
Original issue with screens: Gradle does not start building custom components (ui/component/*) · Issue #6 · openremote/custom-project · GitHub
There is a custom application and a custom UI component package. Here is the structure
Executing the command ./gradlew clean installDist
, the build crashes.
The problem is that cradle starts building a custom application when the package of a custom component is not built.
The limitation on links sucks. Check issue
You can see that the gradle installDist task
was completed in the package of the custom component, but the package was not built.
The root package.json contains an indication of ui/component as a workspace, and an additional indication of the order of workspaces has no effect
Rich
February 26, 2024, 10:42pm
2
Limitation for posting links is a standard feature of discourse for new users who haven’t “been around the forum much” and should disappear with time.
Your :ui:app:predict:installDist
task shouldn’t need to be different to the custom app example included in the project template, note the dependency on npmBuild
task which will call the build script defined in your package.json
and this should call the webpack build
command and from there the ts-loader
should compile your typescript code before it is bundled.
For typescript code to be compiled for all dependencies you need to ensure your dependencies are included in the tsconfig.json
of your app in the references
section you should reference each of your custom components.
NOTE: yarn install task should be automatically run by gradle
./gradlew :ui:app:custom:installDist --dry-run
Shows these tasks (see yarnInstall
task at top):
:yarnInstall SKIPPED
:openremote:model:compileJava SKIPPED
:openremote:model:processResources SKIPPED
:openremote:model:classes SKIPPED
:openremote:model:jar SKIPPED
:openremote:container:compileJava SKIPPED
:openremote:container:compileGroovy SKIPPED
:openremote:container:processResources SKIPPED
:openremote:container:classes SKIPPED
:openremote:container:jar SKIPPED
:openremote:agent:compileJava SKIPPED
:openremote:agent:compileGroovy SKIPPED
:agent:processResources SKIPPED
:agent:classes SKIPPED
:agent:jar SKIPPED
:model:jar SKIPPED
:openremote:agent:processResources SKIPPED
:openremote:agent:classes SKIPPED
:openremote:agent:jar SKIPPED
:openremote:model-util:compileJava SKIPPED
:openremote:model-util:processResources SKIPPED
:openremote:model-util:classes SKIPPED
:openremote:model-util:jar SKIPPED
:openremote:ui:component:model:compileJava SKIPPED
:openremote:ui:component:model:compileGroovy SKIPPED
:openremote:ui:component:model:generateTypeScript SKIPPED
:openremote:ui:component:rest:compileJava SKIPPED
:openremote:ui:component:rest:compileGroovy SKIPPED
:openremote:ui:component:rest:generateTypeScript SKIPPED
:ui:app:custom:npmBuild SKIPPED
:ui:app:custom:installDist SKIPPED
system
Closed
May 26, 2024, 10:42pm
3
