Hello all, actually when iam plotting graphs, iam only getting a straight line , not getting any other graphs. what is the solution for it.
Hi @aishawaryam
The vertical line should indicate your actual time.
Make sure you checked “store data points” configuration item in the attribute you want to see in the graph, and check the graph time range
Hi , i tried by giving tick mark in store data points for the configuration item, but still my graph is coming like a straight line, i checked store data items for all the parameters that i have to plot
Are you seeing any data in the chart on the respective asset pages?
