my situaiton is as follows:
Every time a KNX switch is pressed, it sends an “on” telegram. Openremote should listen to these telegrams and perfom some tasks in response.
I’ve setup an openremote sensor bound to the group address of the KNX switch and some Drools to handle the event.
For the first telegram everything is fine. But then the sensor has state “on” and the rules don’t fire any more… ( the sensor value did not change…)
How can we listen for telegrams on a “raw level”, despite the value did change or not?
(I’ve already tried to retract the sensor event, but then I end up in an endless loop. . )
Thanks and best regards,
Markus
ps:
the Drools used is simply something like:
rule
when
$e : Event(source==“myKnxSwitchSensor”) // no conditions here …
then
// do something…
retract($e) // -> endless loop …
end
