I tried this on several hosts, in our local lab and a datacenter. All were running some kind of RHEL-ish distro, most AlmaLinux 8 oder 9.
No other applications / containers are running on those machines.
The haproxy from the docker stack is stuck in a start loop with the following log entries:
openremote-proxy-1 | [INFO][2024-01-11 13:27:34] HAPROXY_USER_PARAMS:
openremote-proxy-1 | [INFO][2024-01-11 13:27:34] PROXY_LOGLEVEL: info
openremote-proxy-1 | [INFO][2024-01-11 13:27:34] LUA_PATH:
openremote-proxy-1 | [INFO][2024-01-11 13:27:34] CERT_DIR: /deployment/certs
openremote-proxy-1 | [INFO][2024-01-11 13:27:34] LE_DIR: /deployment/letsencrypt
openremote-proxy-1 | [INFO][2024-01-11 13:27:34] Checking HAProxy configuration: /etc/haproxy/haproxy.cfg
openremote-proxy-1 | Configuration file is valid
openremote-proxy-1 | [INFO][2024-01-11 13:27:34] Starting crond
openremote-proxy-1 | [INFO][2024-01-11 13:27:34] cert_init...waiting 10s for haproxy to be ready
openremote-proxy-1 | [INFO][2024-01-11 13:27:34] Starting monitoring process
openremote-proxy-1 | [INFO][2024-01-11 13:27:34] HAProxy starting
openremote-proxy-1 | [INFO][2024-01-11 13:27:34] Monitoring config file '/etc/haproxy/haproxy.cfg' and certs in '/deployment/certs' for changes...
openremote-proxy-1 | [NOTICE] (1) : haproxy version is 2.7.8-58c657f
openremote-proxy-1 | [ALERT] (1) : Not enough memory to allocate 1073741815 entries for fdtab!
openremote-proxy-1 | [ALERT] (1) : No polling mechanism available.
openremote-proxy-1 | This may happen when using thread-groups with old pollers (poll/select), or
openremote-proxy-1 | it is possible that haproxy was built with TARGET=generic and that FD_SETSIZE
openremote-proxy-1 | is too low on this platform to support maxconn and the number of listeners
openremote-proxy-1 | and servers. You should rebuild haproxy specifying your system using TARGET=
openremote-proxy-1 | in order to support other polling systems (poll, epoll, kqueue) or reduce the
openremote-proxy-1 | global maxconn setting to accommodate the system's limitation. For reference,
openremote-proxy-1 | FD_SETSIZE=1024 on this system, global.maxconn=536870889 resulting in a maximum of
openremote-proxy-1 | 1073741815 file descriptors. You should thus reduce global.maxconn by 536870396. Also,
openremote-proxy-1 | check build settings using 'haproxy -vv'.
openremote-proxy-1 exited with code 1
Has anybody seen this and has some quick pointers as to where / how to fix this?
Or do I have to do some deep diving myself?
Oh, and I forgot to mention this before: As there’s the obvious line “Not enough memory” - all test machines had at least 32 GB of RAM free at the time of testing. I suppose this should be enough for a simple test setup?
Yeah, that looks like it. Docker is on version 24 on all our systems.
I suppose there’s no easy way to change the haproxy config with rebuilding the docker image myself?
As mentioned in the docker-compose.yml file you sent,
you can provide a custom config usingthe HAPROXY_CONFIG environment variable.
The config file we use can be found here.
Our proxy image is available on GitHub here, but it’s basically only a wrapper around HAProxy.
Feel free to use a different proxy, or use the repo and build a local image if you need to.
thanks for taking your time to answer here. I loaded a custom config with a global maxconn for haproxy, which let’s it start correctly.
After that I cannot even get any webpage, I just get an empty page. dev console shows requests for manager_config.json, keycloak.min.js, or.json run into a 404. A request for /register gives a 403.
I found some posts about putting a default manager_config.json to the deployment folder, but that doesn’t get picked up there as it seems (still 404).
All in all it seems that’s not a way to quickly fire up a basic local test instance of OpenRemote (which is what I wanted to to basically, while fiddling around with some ideos for usage).
I’ll have to drop it here and perhaps revisit this if I can make some more free time to experiment.
Thanks for bringing this to our attention. I have now created a new openremote/proxy:latest image which should solve the problem, just pull this latest image:
docker compose -p or pull proxy
NOTE: if you are using a custom haproxy.cfg then you might need to make changes as haproxy seems to have made breaking changes to how they process " within redirect statements.
