Hallo I've used open remote since 1 year to control my knx blinds, I used rules too, everything using my raspberry and all worked fine. One week ago a thunderstorm caused a black out and I was obliged to reinstall everything. Unfortunately from that day I've problems with rules and blind's slides (in particular I can't check the state), please can you help me, I paste my log.
INFO 2016-06-13 21:04:16,262 (KNX): KNX IP interface hostname set to 'null'
INFO 2016-06-13 21:04:16,277 (KNX): KNX IP interface port set to '3671'
INFO 2016-06-13 21:04:16,279 (KNX): KNX PhysicalBus clazz set to 'org.openremote.controller.protocol.port.DatagramSocketPort'
INFO 2016-06-13 21:04:16,293 (KNX): Scheduled reconnection task
INFO 2016-06-13 21:04:16,299 (KNX): Trying to create connection
INFO 2016-06-13 21:04:16,301 (KNX): Removing connection
WARN 2016-06-13 21:04:16,307 (KNX): Unknown KNX property '<property name = "name" value = "Tapparella stato Lorenzo"/>'.
INFO 2016-06-13 21:04:16,328 (KNX): KNX Connection manager resolving local host IP addresses...
INFO 2016-06-13 21:04:16,351 (KNX): Found candidate NIC: name:eth0 (eth0)
INFO 2016-06-13 21:04:16,361 (KNX): Skipped IPv6 address (not supported by KNX)
INFO 2016-06-13 21:04:16,364 (KNX): Added candidate IP address to set - /192.168.1.161
INFO 2016-06-13 21:04:16,373 (KNX): Skipping loopback interface: name:lo (lo)
INFO 2016-06-13 21:04:17,568 (KNX): Found a KNX IP interface at /192.168.1.31:3671
INFO 2016-06-13 21:04:17,735 (KNX): Created KNX Command [FRAME] L_Data.req 0.0.0 -> 0/1/2 Data: 0x00 for group address '0/1/2'
INFO 2016-06-13 21:04:17,748 (KNX): Connection created for KNX IP interface at /192.168.1.31:3671
INFO 2016-06-13 21:04:17,756 (KNX): Found a KNX IP interface at /192.168.1.32:3671
INFO 2016-06-13 21:04:17,824 (KNX): Notified with KNX interface status = connected
INFO 2016-06-13 21:04:17,826 (KNX): Connected to KNX-IP interface /192.168.1.31:3671
INFO 2016-06-13 21:04:17,847 (KNX): KNX-IP socket listener IOException
java.net.SocketException: Socket closed
at java.net.PlainDatagramSocketImpl.receive0(Native Method)
at java.net.AbstractPlainDatagramSocketImpl.receive(AbstractPlainDatagramSocketImpl.java:145)
at java.net.DatagramSocket.receive(DatagramSocket.java:786)
at org.openremote.controller.protocol.port.DatagramSocketPort.receive(DatagramSocketPort.java:78)
at org.openremote.controller.protocol.knx.ip.IpProcessor$PhysicalBusListener.run(IpProcessor.java:82)
WARN 2016-06-13 21:04:17,858 (KNX): KNX-IP socket listener stopped
INFO 2016-06-13 21:04:17,860 (KNX): Stopping connection timer
WARN 2016-06-13 21:04:18,065 (KNX): Unknown KNX property '<property name = "name" value = "Tapparella stato Studio"/>'.
INFO 2016-06-13 21:04:18,071 (KNX): Created KNX Command [FRAME] L_Data.req 0.0.0 -> 0/4/2 Data: 0x00 for group address '0/4/2'
WARN 2016-06-13 21:04:18,237 (KNX): Unknown KNX property '<property name = "name" value = "Tapparella stato WC Gianlu"/>'.
INFO 2016-06-13 21:04:18,251 (KNX): Created KNX Command [FRAME] L_Data.req 0.0.0 -> 0/6/2 Data: 0x00 for group address '0/6/2'
WARN 2016-06-13 21:04:18,389 (KNX): Unknown KNX property '<property name = "name" value = "Letto Stato"/>'.
INFO 2016-06-13 21:04:18,391 (KNX): Created KNX Command [FRAME] L_Data.req 0.0.0 -> 0/0/3 Data: 0x00 for group address '0/0/3'
WARN 2016-06-13 21:04:18,511 (KNX): Unknown KNX property '<property name = "name" value = "Tapparella stato cucina"/>'.
INFO 2016-06-13 21:04:18,513 (KNX): Created KNX Command [FRAME] L_Data.req 0.0.0 -> 0/3/2 Data: 0x00 for group address '0/3/2'
WARN 2016-06-13 21:04:18,577 (KNX): Unknown KNX property '<property name = "name" value = "Tapparella stato WC Sery"/>'.
INFO 2016-06-13 21:04:18,580 (KNX): Created KNX Command [FRAME] L_Data.req 0.0.0 -> 0/5/2 Data: 0x00 for group address '0/5/2'
WARN 2016-06-13 21:04:18,643 (KNX): Unknown KNX property '<property name = "name" value = "Tapparella stato Salone"/>'.
INFO 2016-06-13 21:04:18,646 (KNX): Created KNX Command [FRAME] L_Data.req 0.0.0 -> 0/2/2 Data: 0x00 for group address '0/2/2'
WARN 2016-06-13 21:04:18,709 (KNX): Unknown KNX property '<property name = "name" value = "Slide Salone"/>'.
WARN 2016-06-13 21:04:18,932 (KNX): Unknown KNX property '<property name = "name" value = "Slide Letto"/>'.
WARN 2016-06-13 21:04:19,012 (KNX): Unknown KNX property '<property name = "name" value = "Slide WC Gianlu"/>'.
WARN 2016-06-13 21:04:19,143 (KNX): Unknown KNX property '<property name = "name" value = "Slide Cucina"/>'.
ERROR 2016-06-13 21:04:19,339 (KNX): KNX Error
java.lang.NullPointerException
at org.openremote.controller.statuscache.rules.RuleEngine.push(RuleEngine.java:145)
at org.openremote.controller.statuscache.EventProcessorChain.push(EventProcessorChain.java:188)
at org.openremote.controller.statuscache.StatusCache.update(StatusCache.java:260)
at org.openremote.controller.model.sensor.Sensor.update(Sensor.java:342)
at org.openremote.controller.protocol.knx.GroupValueRead.updateSensor(GroupValueRead.java:356)
at org.openremote.controller.protocol.knx.KNXIpConnectionManager$KNXConnectionImpl.handleLDataInd(KNXIpConnectionManager.java:975)
at org.openremote.controller.protocol.knx.KNXIpConnectionManager$KNXConnectionImpl.receive(KNXIpConnectionManager.java:737)
at org.openremote.controller.protocol.knx.ip.IpTunnelClient.notifyMessage(IpTunnelClient.java:229)
at org.openremote.controller.protocol.knx.ip.IpProcessor$PhysicalBusListener.run(IpProcessor.java:102)
ERROR 2016-06-13 21:04:22,287 (KNX): KNX Error
ERROR 2016-06-13 21:04:25,309 (KNX): KNX Error
ERROR 2016-06-13 21:04:28,330 (KNX): KNX Error
ERROR 2016-06-13 21:04:31,352 (KNX): KNX Error
ERROR 2016-06-13 21:04:34,373 (KNX): KNX Error
ERROR 2016-06-13 21:04:37,401 (KNX): KNX Error
