Help updating attribute with specific timestamp
I am trying to make code to store historic data, in case my network connection have been down, I want the attribute values collected during the network downtime, to be sent to the serer once the network connection is restored.
I read the documentation here:
and there are a method mentioned where I should use the endpoint
/api/master/asset/{assetID}/attribute/{attributeName}/{timestamp}
BUT if I do etc.
/api/master/asset/5NjH8Zl2d36EuqCItcjwJ5/attribute/temperature/1746284228
I get an error 404 NOT found
If I remove the timestamp and do like this
I get an error 406 Not acceptable
I also tried the solution mentioned here:
And then add json body like this
“ref”: {
“id”: “5NjH8Zl2d36EuqCItcjwJ5”,
“name”: “temperature”,
“timestamp”: 1746284228
“value”: 25
or like this
“ref”: {
“value”: 25,
No matter what I try, I get errors.
Anyopne that can help?
I had the same need when that functionality was not yet possible in OR. Now, I can’t use it either, but that’s another story. So I wrote my code to allow direct writing to PostgreSQL from OR, it’s always good to have a plan B!
Yeah but would rather like to have it using the API. and it seems it should be possible.
So… Anyone?
I think the timestamp you’re using is not in milliseconds?
Using 1746284228000 might solve your issue.
I still did not get thos working.
OpenRemote manual says ISO8601 should be used, I tried timestamp in s and ms, and iso8610
I tried endpoint like
/api/realm/asset/attributes/timestamp
and
I tried formats like
“ref”: {
“id”: “4w9DWq8oVne4c51zvbHsCf”,
“name”: “TemeStampTest”
“value”: 95,
“timestamp”: “2025-07-08T00:00:00Z”
And
“ref”: {
“value”: 95,
“timestamp”: 1749369600000
nothing works.
Can anyone please tell me, is it even possible to upload historic data to OpenRemote?
If I use this endpoint you already mentioned. It works for me:
Did you also try that one with the correct time in millis?
Can you use other endpoints to e.g. get info from that asset?
Hi Don,
unfortunately the documentation is not clear enough, what would be the format json to put in the body?
I put:
{"value": 0.601}
and I received a 406 http error:
	"ref": {
		"id": "3pZuulVAbs7jIk6GHwAegI",
		"name": "ratioEnergy"
	"failure": "INVALID_VALUE"
Hi Paco!
In case of a single attribute update, the payload should be the raw value in itself.
So it’s not necessarily a JSON Object, but a JSON value like a number or string.
For example;
'test message'
curl -L -X PUT 'http://<hostname>/api/master/asset/3ZhpgRBZXTtpU4vRUT1pB1/attribute/notes/1752665582860' -d 'test message'
or in case of numbers
0.601
curl -L -X PUT 'http://<hostname>/api/master/asset/3ZhpgRBZXTtpU4vRUT1pB1/attribute/amount/1752665582860' -d '0.601'
It’s on our roadmap / radar to improve the HTTP API documentation.
But I hope this helps!
Yes, putting only the value works. However, it seems that there are some peculiarities depending on the timestamp used, which may be what causes confusion when testing the endpoint. The timestamp restrictions don’t make sense to me, and you should be able to allow any timestamp, even future ones. I suppose it must be related to the inner workings of OR.
Well, it doesn’t matter, for some uses it will serve me, for others it will not.
Thanks Martin
