Hi, I am trying to get a token over the endpoint /auth/realms/{realm}/protocol/openid-connect/token, but I only get:
Can someone help me please?
Did you replace {realm} with the actual realm name? ![]()
Otherwise elaborate a bit further on your setup and attempts to make it work please.
Don
Hi @Don , thanks for your reply!
Oh yes I replaced {realm} with “master”. I posted the wrong screenshot … this is what I get:
The status is: 405 Method Not Allowed
Any idea how to fix this issue?
Is this an issue from my side or is it an issue of OpenRemote? ![]()
With the use of Postman it works now.
What I have done:
x-www-form-urlencoded option and enter the following parameters:grant_type: client_credentialsclient_id: {name-of-service-user}client_secret: {generated-secret-of-service-user}For getting information about a specific asset I did the following:
Authorization header to the request and set the value to Bearer {access_token}, where {access_token} is the access token obtained in the previous step.Hi Chief,
Great that you got it to work. Thanks for posting the steps you took! ![]()
Don
Thank you chief,
I stuck in this since long, but after getting your post it become so easy for me, one question, access-token expiring in 1 minute I think, how can we increase time?
Hi faraz, your welcome! Good question. I wrote a Python-script which automatically asks for a new token everytime it gets executed. But how you can change it in another way I do not know unfortunately.
@faraz003: do you fix 401 Unauth error? I meet similar issue like you do. Thanks
Please describe the steps you have tried in your case.
@deputy-chief-hardy gave a brief description on how it should work,
and it should be similar to oAuth2 standards. External use like Postman or use in your own application should use a Service user and the client_credentials grant as described.
Also feel free to open a new topic.
Maybe useful for you: Release: OpenRemote Postman API Collection with fix for OAuth Authentication
