Well, as no one seems to be responding I’ll consider the timestamps shown in the OR charts to be local time. In fact, this is how it should be considered if not stated otherwise.
I’m now receiving data through a RESTful API. The first value contains a TS=‘2024-09-20 00:00’, it’s local time. With Java I convert it to Epoch time and also add an offset corresponding to 2 hours:
1st step: 1726783200000 (2024-09-19 22:00+0000) ← This one is correct
2nd step: 1726790400000 (2024-09-20 00:00+0000) ← This one would be false
This last value is the one I use to save it in OR:
datapointService.upsertValue(assetId, CustomAsset.ENERGY_IMPORT.getName(), ai, timestampMillis);
Why am I doing this? This is the way to see ‘2024-09-20 00:00’ in both Postgres and OR charts. Does it make sense?
OK, so let’s imagine now that I want to get OR data from its API. The API returns epoch time, and if in Postgres I see ‘2024-09-20 00:00’, the corresponding timestamp returned by the API is 1726783200000, which is ‘2024-09-19 22:00+0000’. Evidently a timestamp that does not correspond to reality.
Has nobody noticed this? I have a hard time to keep remembering the unequal conversion type as I write or read in OR.
Another example with timezone, now I integrated the electricity prices using an API. I get for the first value:
“value”: 59.36,
“datetime”: “2024-10-03T00:00:00.000+02:00”
This represents a cost ot 0.05936€/kWh from 00h-01h local time. I can see it perfectly in the graph and in the DB.
However, to write that value, I used a timestamp 1727913600000, as ISO 2024-10-03 00:00+0000, which is wrong in relation to reality again.
