Hi @aishwaryam
I’m not sure you can do that. The timeframe you chose is “Day” so it picks exactly 24 hours. You can achieve the same thing by choosing the end date
What @pcr mentions is correct. You can only show the last 60 minutes,
24 hours, 7 days, et cetera before the end date you specified.
It’s funny that we’re currently working on improvements of the chart,
with more flexibility in control as well. I’ll keep you up to date ![]()
I also found hard to set the time from the computer keyboard. For example, when I type 1 in the hour field, it changes to 7 and when I try to change the minutes field the hour, and sometimes the day, also change. Is that a bug or do I need to check something in my browser?
That is a known bug @juannmr20 ![]()
