I’d like to apply a map on openremote as a leaflet, so could you tell me how? I’m looking for advice.
Thank you for your advice!
Are you referring to ‘leaflet’ as the JavaScript Map library?
As in, being able to load a Leaflet configuration in the OpenRemote UI?
That’s right. I think we need to apply leaflet openstreetmap to openRemote, is there a way?
Our map in the OpenRemote UI uses MapLibre to load vector and raster tiles.
(although vector tiles are more often used by users)
I’m less familiar with Leaflet, but I do know that they’re using raster tiles (.png) for rendering.
Can’t you use the same OpenStreetMap source?
We have documentation on setting up the map here:
I’ll give it a try!
Thank you for you reply.
I have an additional question.
I converted the mbtile format, how can I apply it to OpenRemote installed in docker?
To apply a new .mbtiles source to the OpenRemote Manager,
you’ll need to insert the file in the docker container.
I just added a command to our “Useful commands and queries” page of our documentation.
See “Insert an .mbtiles file for applying a different map”:
By default, the file should be uploaded in
/deployment/map/mapdata.mbtiles.
The environment variableOR_MAP_TILES_PATHcan be used to change this default path.
