DEPLOYING NEW CONTROLLER RUNTIME…
INFO 2021-10-11 03:10:36,333 : No rule definitions found in ‘/opt/OpenRemote-Con troller/webapps/controller/rules’.
INFO 2021-10-11 03:10:36,333 : Initialized event processor : Drools Rule Engine
INFO 2021-10-11 03:10:36,354 : Initialized event processor : RRD4J Data Logger
INFO 2021-10-11 03:10:36,355 : Initialized event processor : EmonCMS Data Logger
ERROR 2021-10-11 03:10:36,377 : Creating sensor failed. Error : null
XML Element :
java.lang.NullPointerException
at org.openremote.controller.model.xml.Version20SensorBuilder.parseSenso rEventProducer(Version20SensorBuilder.java:429)
at org.openremote.controller.model.xml.Version20SensorBuilder.build(Vers ion20SensorBuilder.java:287)
at org.openremote.controller.deployer.Version20ModelBuilder.buildSensorO bjectModelFromXML(Version20ModelBuilder.java:817)
at org.openremote.controller.deployer.Version20ModelBuilder.buildSensorM odel(Version20ModelBuilder.java:663)
at org.openremote.controller.deployer.Version20ModelBuilder.build(Versio n20ModelBuilder.java:557)
at org.openremote.controller.deployer.AbstractModelBuilder.buildModel(Ab stractModelBuilder.java:154)
at org.openremote.controller.service.Deployer.startup(Deployer.java:872)
at org.openremote.controller.service.Deployer.softRestart(Deployer.java: 454)
at org.openremote.controller.service.Deployer$ControllerDefinitionWatch. run(Deployer.java:1411)
at java.base/java.lang.Thread.run(Thread.java:829)
ERROR [Controller Definition File Watcher for Default Deployer]: Creating sensor failed. Error : null
XML Element :
ERROR 2021-10-11 03:10:36,383 : Creating sensor failed. Error : null
XML Element :
XML Element :
INFO 2021-10-11 03:10:36,384 : Startup complete.
