I have a device which is publishing to an attribute now I want to make connection with attribute to get data as soon as it is published. I want to make it realtime using websocket apis but I am unable to find how can I subscribe to attribute for realtime update?
There is some documentation on the GitHub wiki to get you started with listening to attribute updates;
this part I am able to achieve but how to do next. I want to subscribe to building device attribute city then how to send here?
wss://localhost:8080/websocket/events?Realm=smartcity&Authorization=Bearer%20eye2238f3a-e43c-3f54-a05a-dd2e4bd4631f&asset=building1&attribute=city
Also, will it be same for publish?
You can only subscribe to attribute events once authenticated.
The URL you’re talking about is to instantiate the connection by authenticating.
So;
- Use
wss://localhost:8080/websocket/events?Realm=smartcity&Authorization=Bearer%20eye2238f3a-e43c-3f54-a05a-dd2e4bd4631fto connect and authenticate with the WebSocket API - Send a JSON message using the EventSubscription format; (as written in the docs)
For example, to subscribe to a single attribute;
SUBSCRIBE:{"eventType": "attribute", "filter": { "ref": { "id": "<asset id>", "name": "<attribute name>" }}
(can’t verify this, and I’m not 100% familiar with the WS API, so check docs if not working)
- You’ll get a message prefixed with
SUBSCRIBED:or an error verifying the subscription.
It sadly involves quite a bit of diving into the JavaDoc, same counts for publishing.
We should write some documentation on this. ![]()
