Hello, I’ve just bought a Fibaro “The Button”.
But unfortunately I can’t figure out how to integrate it in Openremote
Does anyone know how to do this?
/Magnus
/Magnus
First of all you have to add the device to the Z-Wave network. The Fibaro Button seems to be a security enabled device, therefore I’m not sure if this device can be included with the hardware button of the Fibaro Z-Stick. In case of a security enabled device you have to include the Fibaro Button with an inclusion software command that is sent to the Fibaro Z-Stick or another Z-Wave interface. That means you have to add an inclusion switch with the commands INCLUSION_MODE_ON, INCLUSION_MODE_OFF, INCLUSION_MODE_STATUS to a panel (see New Z-Wave 2.0.0 Release).
After device inclusion an association from the device to the controller (Z-Wave node ID 1) has to be configured so that the device knows where to send Z-Wave commands after the button has been pressed. After successful inclusion of a device you’ll find a nodeX.xml (X : Z-Wave node ID) file in the directory /webapps/controller/zwave. Open this file with an editor and add the following association :
** ** ** 1 ** ...<wake-up interval="..." />
After editing this file restart the controller and wake up the Fibaro Button so that it’s possible for the controller to configure the Z-Wave device.
I’m not 100% sure but I think that the Fibaro Button supports COMMAND_CLASS_SCENE_ACTIVATION. If this is true add the command STATUS_SCENE_ID to your configuration and create a related range sensor (0 - 10). For test purposes add a label to a panel and link the label with the STATUS_SCENE_ID command. After pressing the button you should see the scene ID on the label.
After reading the Fibaro Button manual I was a bit confused because they claim that the button sends always scene ID 1 to the controller no matter how many times you press the button ? Doesn’t make sense to me. I was expecting that the button sends a different scene ID depending on how many times the button was pressed. Let’s see because these manuals are not always 100% correct.
Thanks for the quick respons.
I’ve managed to include the device into the Z network and a .xml file was created (se below)
Maybe this can be of some help… (node 13 is the Fibaro button)
When I pushed the button two times the following was found in the z wave log-file
Node ‘13’ : [APP_CMD_HANDLER_FRAME : NodeID=‘13’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_CENTRAL_SCENE’, Command=‘0x03’, Parameters: [0x04, 0x03, 0x01]]
DEBUG 2016-08-17 20:01:21,106 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-08-17 20:01:21,107 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x10, 0x00, 0x04]
DEBUG 2016-08-17 20:01:21,107 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x00]
DEBUG 2016-08-17 20:01:21,107 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x06, 0x0A, 0x32, 0x02, 0x21, 0x34, 0x00, 0x00, 0x00]
DEBUG 2016-08-17 20:01:21,107 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0xAC]
DEBUG 2016-08-17 20:01:21,108 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x00]
DEBUG 2016-08-17 20:01:21,108 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x00, 0x6E]
DEBUG 2016-08-17 20:01:21,108 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x10, 0x00, 0x04, 0x00, 0x06, 0x0A, 0x32, 0x02, 0x21, 0x34, 0x00, 0x00, 0x00, 0xAC, 0x00, 0x00, 0x6E] has been received.
DEBUG 2016-08-17 20:01:21,109 (Z-Wave): RX_Session_Layer
/Magnus
It seems that the Fibaro Button doesn’t support the Z-Wave command class COMMAND_CLASS_SCENE_ACTIVATION. Fibaro utilizes the command class COMMAND_CLASS_CENTRAL_SCENE in order to send scene information. Unfortunately this command class is currently not supported.
That was not good
Is there any chance that the command class will be supported in the near future?
Yes I intend to implement COMMAND_CLASS_SCENE_ACTIVATION in the near future but no guarantees when it’s ready.
That sounds great, thanks.
I'll be waiting patiently
I asked Fibaro support if they could shed some light over my button problem.
I received this answer:
“Probably attached files (API and LUA scene) can show you what is a central scene – it is new command class to trigger scenes, and it an event type.”
see attached files…
Maybe this can be of some help when you implement the command class.
The following new Z-Wave protocol version supports COMMAND_CLASS_CENTRAL_SCENE and has been tested with the Fibaro Button.
I’ve replaced the zwave.jar file.
And when I try to start the controller it looks good in the beginning of the startup process.
It’s using the new file 3.1.0 Beta1.
But after opening the COM-port and starting some Node’s it stops and the following errors occurs.
Any suggestion what to do?
My Z-network consist of a Z-stick (Aeotec gen5) and Openremote is running on a QNAP NAS (TS-453A).
As always any help is appreciated
Java version 1.8.0_65
The following version should fix this bug that creeped in with the new implementation :
