i want to setup openremote as PWA using progressier.com. please let me know if anyone done already?
First of all, hi! Welcome to the forum
To clarify;
OpenRemote contains a manager backend with lots of logic, publicly exposed APIs etc
It also requires both a Keycloak authentication service and a PostgreSQL database.However, the UI is completely flexible, and can be applied in many different ways.
The “Manager UI” is built using TypeScript and uses a low-level web component framework called Lit.
Technically you can build custom apps in any language you want, and simply interact using the
HTTP API, which we do ourselves as well.
In regards to your PWA use case;
I haven’t seen users busy with PWAs for interacting with OpenRemote, but it is defenitely possible.
Are you planning to build a custom app, or are you trying to make the Manager UI act as a PWA?
