Hi, i am using a HTTP command with JSON Path Expression to display a value from my solar cloud (Zever Solar).
Log file:
javax.net.ssl.SSLException: hostname in certificate didn’t match: <www.zevercloud.com> != <.ucdl.pp.uc.cn> OR <.ucdl.pp.uc.cn>
at org.apache.http.conn.ssl.AbstractVerifier.verify(AbstractVerifier.java:220)
at org.apache.http.conn.ssl.BrowserCompatHostnameVerifier.verify(BrowserCompatHostnameVerifier.java:54)
at org.apache.http.conn.ssl.AbstractVerifier.verify(AbstractVerifier.java:149)
at org.apache.http.conn.ssl.AbstractVerifier.verify(AbstractVerifier.java:130)
at org.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:339)
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:123)
at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:147)
at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:108)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:415)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:641)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:731)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:709)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:700)
at org.openremote.controller.protocol.http.HttpGetCommand.requestURL(HttpGetCommand.java:202)
at org.openremote.controller.protocol.http.HttpGetCommand.read(HttpGetCommand.java:216)
at org.openremote.controller.model.sensor.Sensor$DeviceReader.read(Sensor.java:729)
at org.openremote.controller.model.sensor.Sensor$DeviceReader.run(Sensor.java:648)
at java.lang.Thread.run(Thread.java:748)
I found API requests via Internet Explorer only works with TLS 1/1.1/1.2 on. So the website redirects when you try to hit HTTP to HTTPS.
Is this a limitation in Open Remote not handling HTTPS? Or is there an actual problem with the Hostname not matching the Certificate?
Command: http://www.zevercloud.com/api/v1/getPlantOverview?key=**********
Some direction is greatly appreciated!
