Data export function exports by downloading a .csv
how can i select the direction of the file
Hi @Naravit
If I try to export I get a zipped file downloaded in my default download folder
What browser are you using?
i try to export from demo version it happen same as u told. But when i try to export my own account i doesn’t work
Data export requires the use of a temp-data docker volume that both postgres and manager docker services can access because the export writes to the file ssystem then the manager picks up that export file and sends it to the client.
You should see this temp-data mentioned in the openremote/docker-compose.yml file; make sure you also have it configured in your docker compose file.
