Dear everyone,
I try to customise the map following the useful wiki. But I got this error when i try to generate output.mbtiles with tilive-copy.
I install node package locally and I try with another nodejs version, but i get the same error.
Previously i am run the command on docker in a Debian Virtual Machine but when i install node on windows and run the command it work perfectly!
Glad to hear hear you figured out the problem
