I want to access my openremote postgres database from external tools (i.e. tableau, crystal report or power BI etc.), currently when I am trying connect with these authentication:
But not able to connect.
Shall I need to do some changes in configuration file of docker compose.
This is the same issue as you described 12 hours ago in this topic:
HI,
How can I access postgres database from outside of OR manager (i.e pgadmin etc), do I need to add host during docker compose up?
Currently my docker compose file is following:
# OpenRemote v3 # # Profile that runs the stack by default on https://localhost using a self-signed SSL certificate, # but optionally on https://$OR_HOSTNAME with an auto generated SSL certificate from Letsencrypt. # # It is configured to use the AWS logging driver. # version: ‘2.4’ volumes: proxy-data: manager-data:…
michal
July 21, 2023, 9:09am
3
Indeed, you need to make a change in docker-compose.yml file for the postgres service using ports directive and expose port 5432.
services:
postgres:
ports:
- "5432:5432"
