Move smalller file mapdata.mbtiles files to local /deployments/map as the docker mounted volume.
No mapsettings.json defined, but if defined notyhing (center maps and bounds defined too) happens. I do not know where to find mapsettings.json corresponding to Openstreetmap vector downloaded.
No error on manager container via logs file mapdata.mbtiles is found and loaded when reload container.
Nothing display y map area. No maps in the interface.
Any help would be appreciated !! I need help. Thanks in advance.
The mapbox styling to use for the vector map data (road colours, etc.)
Manager UI map widget settings (initial centre point, zoom level, etc.)
So if you are providing a custom mapdata.mbtiles then you need to also provide custom centre point values for the map widget as by default the centre point and bounds will be around Rotterdam.
mapsettings.json is explained in the wiki article here
As you can see the mapping is ./deployment/ and you are putting mbtiles in /deployments/map. Not only it isn’t a subdirectory to the current path but it has extra ‘s’ letter at the end.
Thxs again for all information. The problem was in mapsettings.json. I took coordinates from google maps to center map (latitude, longitude) but in mapsettings.json is defined (longitude, latitude).
