Insights view page button redirects to blank page?
Hello.
Previously when I used this feature it would open a new tab in my browser showing a dashboard only, with access to only other dashboards. This was handy because I could give other users this url, a username and password to view just the dashboards. Now it just points to a blank page.
Here is a screenshot of the browser button I am referring to:
Screenshot 2025-04-16 at 18.02.59
in my opinion the same cause and error as
https://forum.openremote.io/t/login-with-another-realm-account-realm-master/3720
I just tested this for myself, and the “redirect URL” seems correct.
The URL should look like this;
https://<your URL>/insights/?realm=<your Realm>#/view/<your Dashboard ID>/true
(the true / false at the end shows/hides the sidebar)
Can you explain what URL you are sent to?
If you could copy / paste the browser console or network logs would be great!
And maybe share some details on your deployment, if you’re using a custom hostname etc.
Hi Martin,
I am using a custom hostname and have now resolved the issue, which is a little odd. if I login with my admin credentials to my master realm and then select my other realm and go to that insights page, it doesn’t work. If I log out of my master realm and log in directly to the other realm it works fine.
