Hi Openremote community,
I encounter problems with installing/running openremote on an AWS ubuntu ec2 instance.
I have a straightforward setup with ubuntu 20 (ubuntu/images/hvm-ssd/ubuntu-focal-20.04-amd64-server-20211021)
- I installed docker and docker-compose.
- I downloaded the openremote
docker-compose.yml - I changed the yml file to different ports:
"8000:80"
"8443:443"
"8883:8883"
I ran:
$ sudo docker-compose pull
Processing: error-openremote.txt…
$ sudo EXTERNAL_URL=https://ec2-35-158-117-242.eu-central-1.compute.amazonaws.com:8443 docker-compose --verbose -p openremote up -d
(I also tried to run this command without EXTERNAL_URL and without changing the default ports, but have the same problems)
sudo docker-compose pull completes correctly.
However, when I run above docker-compose openremote up -d, the installation hangs on the openremote manager.
I have no idea why. Below I added the last part of the logging when running the docker-compose up command in verbose mode. At the end of the log you can see there is something wrong with a timeout. Something with http://localhost:None ?
Could somebody help me with this?
Kind regards,
Martijn van der Plaat
–LOGGING–
compose.cli.verbose_proxy.proxy_callable: docker inspect_container -> {'AppArmorProfile': 'docker-default',
'Args': ['/bin/sh',
'-c',
'java $MANAGER_JAVA_OPTS -cp '
'/opt/app/lib/*:/deployment/manager/extensions/* '
'org.openremote.manager.Main'],
'Config': {'AttachStderr': False,
'AttachStdin': False,
'AttachStdout': False,
'Cmd': ['/bin/sh',
compose.parallel.feed_queue: Pending: {<Service: proxy>}
compose.cli.verbose_proxy.proxy_callable: docker containers <- (all=False, filters={'label': ['com.docker.compose.project=openremote', 'com.docker.compose.service=manager', 'com.docker.compose.oneoff=False']})
urllib3.connectionpool._make_request: http://localhost:None "GET /v1.35/containers/json?limit=-1&all=0&size=0&trunc_cmd=0&filters=%7B%22label%22%3A+%5B%22com.docker.compose.project%3Dopenremote%22%2C+%22com.docker.compose.service%3Dmanager%22%2C+%22com.docker.compose.oneoff%3DFalse%22%5D%7D HTTP/1.1" 200 None
compose.cli.verbose_proxy.proxy_callable: docker containers -> (list with 1 items)
compose.cli.verbose_proxy.proxy_callable: docker inspect_container <- ('2d5247b535b41356c8fa708db906e58a4021de025e2863b56568703169ba0a1d')
urllib3.connectionpool._make_request: http://localhost:None "GET /v1.35/containers/2d5247b535b41356c8fa708db906e58a4021de025e2863b56568703169ba0a1d/json HTTP/1.1" 200 None
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
'Args': ['/bin/sh',
'-c',
'Cmd': ['/bin/sh',
ERROR: compose.cli.errors.log_timeout_error: An HTTP request took too long to complete. Retry with --verbose to obtain debug information.
If you encounter this issue regularly because of slow network conditions, consider setting COMPOSE_HTTP_TIMEOUT to a higher value (current value: 60).
