Hi there,
I’m trying to run a custom deployment of OpenRemote following the steps mentioned in the Custom Deployment User Guide.
1- Set up the environment:
java --version
java 17.0.10 2024-01-16 LTS
Java™ SE Runtime Environment (build 17.0.10+11-LTS-240)
Java HotSpot™ 64-Bit Server VM (build 17.0.10+11-LTS-240, mixed mode, sharing)
yarn --version
1.22.22
docker --version
Docker version 24.0.2, build cb74dfc
docker-compose --version
Docker Compose version v2.18.1
2- Cloned the custom-project template repository and initialized the openRemote submodule.
3- Ran the command: docker-compose -f profile\dev-testing.yml up --build -d. The keycloak and postgres containers are up and healthy:
4- Ran ./gradlew modelWatch, which executed successfully
5- Attempted to browse: http://localhost:9000/manager/ after running npm run serve -- --env config=..\..\..\..\deployment\manager\app from openremote/ui/app/manager.
However, the OpenRemote blank page showed up for a second, then redirected to: http://localhost:8080/auth/realms/master/protocol/openid-connect/auth?client_id=openremote&redirect_uri=http%3A%2F%2Flocalhost%3A9000%2Fmanager%2F&state=94827a09-ee18-490f-8e08-39ac8bb394b4&response_mode=fragment&response_type=code&scope=openid&nonce=da9df74b-bf70-484c-8268-60e41e7cef43
I received a “connection refused” error, as there is nothing running on port 8080.
Please help me figure out what I’m missing here.
