I’m encountering a strange issue with my custom project based on OpenRemote. Here are the details:
- When I modify certain visual elements in my custom project (like the favicon, mobile logo, etc.), the changes are applied correctly.
- However, when I try to change the main logo, it doesn’t display as expected. Instead, the system defaults to showing the favicon.
- I’ve ensured that the file path is correct in
manager_config.json, and the logo file is present in the expected location. Other files (like the favicon) work without issues.
What I’ve tried:
- Restarting the Docker containers after making changes.
- Clearing my browser cache (CTRL + F5, etc.).
- Checking the logs, which confirm that
manager_config.jsonis being saved correctly:
javascript
CopierModifier
Saving manager_config.json to: /storage/manager/manager_config.json
- Synchronizing the Docker volumes to ensure that the
manager_config.jsonfile in the container matches the local file.
Outcome:
- The issue persists only for the main logo.
- Instead of displaying the updated logo, the system continues to show the favicon.
I don’t understand why this issue occurs only with the main logo. Could it be related to some specific behavior in OpenRemote or a misconfiguration on my end?
Questions:
- Is there an internal caching mechanism or another configuration file I should check?
- Does the system handle the main logo differently compared to other images (favicon, mobile logo, etc.)?
- Is there a specific step required to force the logo update?
Thank you in advance for your help!
