I am trying to deploy OpenRemote v3 on my windows machine. But I am facing below errors.
“Error response from daemon: Ports are not available: listen tcp 0.0.0.0:80: bind: An attempt was made to access a socket in a way forbidden by its access permissions”
I used the below steps for setting up environment.
- Make sure you have Docker Desktop installed (v18+).
- Download the docker compose file: OpenRemote Stack (Right click ‘Save link as…’)
- In a terminal
cdto where you just saved the compose file and then run:
docker-compose pull
docker-compose -p openremote up
