JSON number formating
Hi there,
I know this is a really silly question but I am struggling to find the correct format for dividing a number by 10. The temperature value is delivered as 460 but I would like it to be viewed as 46.0 which is the correct value.
I am extracting the value from a JSON payload using the ‘Attribute links’ functionality as per the below extract.
“ref”: {
“id”: “5GKKFffN3EHo6XyyNQ4vbT”,
“name”: “ModemTemp”
“filters”: [
“type”: “jsonPath”,
“path”: “$.GatewayGSM.modemtemp”,
“returnFirst”: true,
“returnLast”: false
Any help or pointing to an example would be much appreciated.
Thanks,
Alan
Based on more reading I now believe the correct solution is to use regex and then stitch together again in JSON. Unfortunately I seem unable to get my regex to save, am I correct in using the “pattern” key for the regex?
First of all, welcome to the forum! :partying_face:
The regex in ‘Attribute links’ should look something like this;
    "type": "regex",
    "pattern": ".*(\\d)$",
    "matchGroup": 1
If interested, you can take a look at the source code for the RegexValueFilter here.
As of now, it supports the fields pattern, matchGroup, and matchIndex.
Hi Martin,
Thank you for the welcome, I have been reading many posts and found the forum a good resource.
Thank you for providing a sample format, I will have a play with this and see how far it can take me.
Thanks :slight_smile:
