Hi all,
I have been using the docker containers to run OpenRemote (same problems on Ubuntu 20 and Windows 10). It runs fine while the docker container is up, but once I run docker-compose restart on it, it seems to fully recreate the postgresql database, even if I tell it to not rebuild the postgresql container, and I’m left with a clean app (no assets, rules, etc).
I’ve also tried changing the docker-compose.yml to have the postgresql volume stored on the local filesystem, with the same result.
The Wiki seems to imply that this is not the intended behaviour of the docker container. Am I using the docker container wrong here? Would appreciate any help!
