Im trying to do a clean install of the platform, but im encountering this problem when executing docker-compose -p openremote up:
ERROR: for keycloak Container “bbedcbaec514” is unhealthy
I am having the same issue
Can you share the docker logs of both the keycloak and postgresql container?
In the most cases its helpful if you delete the keycloak.json file in “/deployment/manager/”
I did make improvements around those temp credentials and manually deleting them shouldn’t be needed with recent manager versions.
As Martin said we need to see the docker logs…
It seems for me the main problem was installing docker desktop on Ubuntu by downloading the .deb package rather than using apt. If I installed using apt and changed the commands to the following (without the ‘-’) it seems to work:
sudo docker compose pull
sudo docker compose -p openremote up
Hope this helps
Yeah newer versions of docker have compose baked in so no need for separate docker-compose anymore.
updating docker-compose resolve the problem. Thanks for the help!
