Keycloak error?
I’m getting this error when running a Docker container inside a Proxmox VM:
Fatal glibc error: CPU does not support x86-64-v2
how do i get around this?
As you’re referring to an issue with Keycloak, you can simply look up their documentation on it.
Looks like their users have found a solution for your problem.
I’m not an expert in Proxmos myself though :joy:
that was indeed a good suggestion :slight_smile:
Thank you!
The cure was changing the CPU from KVM64 to host on proxmox
