I am deploying Central + Edge on a small home server (Debian 13, Intel Pentium Silver N6005). That CPU has SSE4.2 but no AVX2, so it is x86-64-v2 only.
docker compose build of a manager image based on openremote/manager:1.29.0 fails with:
Fatal glibc error: CPU does not support x86-64-v3
Hub layers show 1.29.0 (and 1.28.0-core) on ubi10-minimal / ubi10/openjdk-21-runtime. UBI 10’s glibc refuses to start Java on this machine. Mosquitto and Zigbee2MQTT are fine.
Would you consider publishing manager (and Keycloak, if it is also UBI 10) for x86-64-v2, for example ubi9/openjdk-21-runtime? If the supported answer is “rebase the published image onto UBI 9 yourself”, that is useful to have in the docs as well.
I can rebuild from source; I would rather stay on the official tags if a v2 image exists or is planned.
