Hi hope everyone is well,
I’m in need of a bit of guidance with my setup of a custom local instance of OpenRemote. I followed the Developer Guide up to setting up an IDE and all works well, used docker desktop, and Intellij CE. But once i run the npm run serve command in cmd it allows me to login but after i can’t modify the white labeling at all.
if anyone has encountered this or know of a way to fix the issue, which i assume is a pathing problem.
Attached is also all my steps to setup the local instance.
npm run serve
IDE instance in intellij CE → running on an older repo for the time being.
attached is every step i followed in the .txt
SetupOpenRemote.txt (432 Bytes)
