Denis
#1
Hey,
i’m getting stuck…
i tried to get a interconnect between to servers, but it doesn’t work, even from realm to realm at the same server.
websocket is ok and reachable. Terminal is giving this msg:
Failed to retrieve OAuth access token for ‘wss://test.floriax.de/websocket/events?Realm=master’: Connection error
is there any part to do at keycloak?
Denis
#2
Ok, the Documentation says, i have to add an identity provider… is there an example for?
Authorization URL?
Token URL ?
Client Authentication ?
Client ID - The Asset ID?
Client Secret - The Asset Secret?
rich
#3
The following guide should assist if you are trying to configure OpenRemote as an Edge Gateway:
Denis
#4
Hey rich,
i followed the guide, but it doesn’t work for me.
Do i have to setup anything in keycloak?
Denis
#5
Rich… i’m so sorry… was my failure… i didn’t installed correctly the ssl certificate…
rich
#6
No problem, good to hear you figured it out!
