Set up your IDE. Note that Application run configurations are already prepared when using this template.
Use docker-compose -f profile\dev-testing.yml up --build -d and run the ‘Custom Deployment’ configuration. You should have two containers running in Docker, and the manager through your IDE."
I use neovim as my code editor. I am running the ‘npm serve – --env=…/…/…/…/deployment/manager/app’ script in my terminal. Is there a manager backend I need to be running?
I only have 1 docker container running called profile.
The difference is that dev-ui runs the manager, while with dev-testing you have to run the manager using the IDE. If you are just working on the UI or a custom app, dev-ui is fine.
Good that you got it to work If you have any more questions feel free to post them.
