is there any option , how i am able to set location for particular asset through mobile app?
I can view only map .
Option 1 would be to create a dedicated app for your application and include the or-map component to set a location.
Option 2 is overwriting the default config of the location panel. On this wiki page click ‘View the example manager_config used in the sections on this page.’ to view the full example and check out the part about the location panel:
"type": "info",
"title": "location",
"properties": {
"include": []
"attributes": {
"include": [
"location"
"itemConfig": {
"location": {
"label": "",
"readonly": false
As you can see I’ve added “readonly”: false. This makes it so that you can set the location in view mode on the asset page by using long press.
Note: in the example a specific asset type is referenced, you can also set a default. Replace this:
"assetTypes": {
"WeatherAsset": {
with this:
"default": {
Good luck ![]()
Thanks , i will try . ![]()
