Migrating OpenRemote to a New AWS Instance — Need Advice
I’m currently in the process of restoring our OpenRemote deployment to a new AWS EC2 instance, following these steps:
  1. Pulled the latest OpenRemote code using the Quick Start guide
  2. Modified the docker-compose.yml to reflect the public IP address of the new instance.
  3. Followed the Backup/Restore OpenRemote DB procedure from the [Developer Guide: Useful Commands and Queries
I also updated the following values in docker-compose.yml to match the values used in the previous production system:
KEYCLOAK_ADMIN_PASSWORD
OR_ADMIN_PASSWORD
After restoring the database and starting the stack, the openremote-manager-1 container remains unhealthy and fails with the message:
‘dependency failed to start: container openremote-manager-1 is unhealthy’
I’d appreciate advice on the best practice for migrating OpenRemote to a new instance.
I have seen this error in the logs depending on the password settings in docker-compose.yml:
manager-1     | 2025-04-06 07:36:14.316  SEVERE  [main                          ] org.openremote.container.Container       : >>> Runtime container startup failed
manager-1     | java.io.IOException: Integrity check failed: java.security.UnrecoverableKeyException: Failed PKCS12 integrity checking
manager-1     |         at java.base/sun.security.pkcs12.PKCS12KeyStore.engineLoad(PKCS12KeyStore.java:2162)
manager-1     |         at java.base/sun.security.util.KeyStoreDelegator.engineLoad(KeyStoreDelegator.java:228)
manager-1     |         at java.base/java.security.KeyStore.load(KeyStore.java:1500)
manager-1     |         at java.base/java.security.KeyStore.getInstance(KeyStore.java:1828)
manager-1     |         at java.base/java.security.KeyStore.getInstance(KeyStore.java:1709)
manager-1     |         at org.openremote.manager.security.KeyStoreServiceImpl.start(KeyStoreServiceImpl.java:107)
manager-1     |         at org.openremote.container.Container.start(Container.java:179)
manager-1     |         at org.openremote.container.Container.startBackground(Container.java:223)
manager-1     |         at org.openremote.manager.Main.main(Main.java:36)
manager-1     | Caused by: java.security.UnrecoverableKeyException: Failed PKCS12 integrity checking
manager-1     |         at java.base/sun.security.pkcs12.PKCS12KeyStore.lambda$engineLoad$2(PKCS12KeyStore.java:2156)
manager-1     |         at java.base/sun.security.pkcs12.PKCS12KeyStore$RetryWithZero.run(PKCS12KeyStore.java:257)
manager-1     |         at java.base/sun.security.pkcs12.PKCS12KeyStore.engineLoad(PKCS12KeyStore.java:2140)
manager-1     |         ... 8 more
manager-1 exited with code 0
Here is my docker-compose.yml:
# OpenRemote v3
  proxy-data:
  manager-data:
  postgresql-data:
services:
  proxy:
    restart: always
    depends_on:
      manager:
        condition: service_healthy
    ports:
      - "80:80" # Needed for SSL generation using letsencrypt
      - "${OR_SSL_PORT:-443}:443"
      - "8883:8883"
      - "127.0.0.1:8404:8404" # Localhost metrics access
      - proxy-data:/deployment
      LE_EMAIL: ${OR_EMAIL_ADMIN:-}
      DOMAINNAME: ${OR_HOSTNAME:-0.123.456.789}
  postgresql:
    restart: always
    shm_size: 128mb
      - manager-data:/storage
  keycloak:
    restart: always
    depends_on:
      postgresql:
      - ./deployment:/deployment
      KEYCLOAK_ADMIN_PASSWORD: ${OR_ADMIN_PASSWORD:-password}
      KC_HOSTNAME: ${OR_HOSTNAME:-0.123.456.789}
  manager:
    privileged: true
    restart: always
    depends_on:
      keycloak:
    ports:
      - "127.0.0.1:8405:8405" # Localhost metrics access
      OR_SETUP_TYPE:
      OR_ADMIN_PASSWORD: ${OR_ADMIN_PASSWORD:-password}
      OR_SETUP_RUN_ON_RESTART:
      OR_EMAIL_HOST:
      OR_EMAIL_USER:
      OR_EMAIL_PASSWORD:
      OR_EMAIL_X_HEADERS:
      OR_EMAIL_FROM:
      OR_EMAIL_ADMIN:
      OR_HOSTNAME: ${OR_HOSTNAME:-0.123.456.789}
      OR_FORECAST_SOLAR_API_KEY:
      OR_OPEN_WEATHER_API_APP_ID:
Hey @Clint ,
This happens because the KeystoreService doesn’t have the correct password to unlock the Keystore that OpenRemote creates. If you had changed the keystore’s password using OR_KEYSTORE_PASSWORD, use that.
Basically, the keystore’s password is going to be OR_KEYSTORE_PASSWORD, if that doesn’t exist then it’s going to be OR_ADMIN_PASSWORD, and if that also does not exist, it’s going to be secret. So the one that the Keystore uses should be the same as with the previous deployment.
If you haven’t used x509 authentication in the MQTT client, you can also delete the keystores in the deployment or tmp directory, they’re called client_keystore.p12 or client_truststore.p12. This will recreate the files.
Let me know if that works!
Thanks Panos
I deleted the following and it seemed to then work very quickly with all the containers healthy and I could log in.
rm /var/lib/docker/volumes/openremote_manager-data/_data/manager/keycloak-credentials.json
rm /var/lib/docker/volumes/openremote_manager-data/_data/keystores/client_keystore.p12
rm /var/lib/docker/volumes/openremote_manager-data/_data/keystores/client_truststore.p12
I then tried to repeat the process and was back to the same problem with container openremote-manager-1 waiting and then failing as unhealthy.
I have tried repeating this process a number of times since but no luck.
I am pretty sure I have the passwords in docker-compose.yml as per the previous deployment.
Any assistance much appreciated.
Hey @Clint ,
Not sure what you mean by repeating the process? Since you deleted the keystores, then they were recreated, and they currently use either OR_KEYSTORE_PASSWORD or OR_ADMIN_PASSWORD.
Hi @panosp
As per below, I seem to be getting through the credential validation process but the openremote-manager-1 container never gets to ‘healthy’ so that I can log in.
I can see rules etc in the logs being uotput to the screen but the manager container seems to be waiting on something.
manager-1     | 2025-04-07 07:18:53.448  INFO    [main                          ] curity.keycloak.KeycloakIdentityProvider : No stored credentials so using OR_ADMIN_PASSWORD
manager-1     | 2025-04-07 07:18:53.454  INFO    [main                          ] curity.keycloak.KeycloakIdentityProvider : Keycloak proxy URI set to: http://keycloak:8080/auth
manager-1     | 2025-04-07 07:18:53.454  INFO    [main                          ] curity.keycloak.KeycloakIdentityProvider : Validating keycloak credentials
manager-1     | 2025-04-07 07:18:57.284  INFO    [main                          ] curity.keycloak.KeycloakIdentityProvider : Credentials are valid
manager-1     | 2025-04-07 07:18:57.288  INFO    [main                          ] curity.keycloak.KeycloakIdentityProvider : OR_ADMIN_PASSWORD credentials are valid so creating/recreating stored credentials
manager-1     | 2025-04-07 07:19:00.125  INFO    [main                          ] curity.keycloak.KeycloakIdentityProvider : Stored credentials successfully generated so using them
manager-1     | 2025-04-07 07:19:00.127  INFO    [main                          ] curity.keycloak.KeycloakIdentityProvider : Keycloak proxy URI set to: http://keycloak:8080/auth
manager-1     | 2025-04-07 07:19:00.130  INFO    [main                          ] curity.keycloak.KeycloakIdentityProvider : Validating keycloak credentials
manager-1     | 2025-04-07 07:19:00.500  INFO    [main                          ] curity.keycloak.KeycloakIdentityProvider : Credentials are valid
Please use code quotation marks for logs etc. makes things easier to read.
So the system just hangs after the Credentials are valid log statement?
Hi Rich
Please see recent topic ‘Procedure to Migrate from OpenRemote Version 1.3.4 to 1.3.5’.
I uploaded the full logs there as per your suggestion.
I suspect the issue may be related to rules we have created slowing things down. If I delete the rules then the restore works. Anyway the full logs may provide some insights.
https://forum.openremote.io/t/procedure-to-migrate-from-openremote-version-1-3-4-to-1-3-5/
